Probe Basic spindle load bar off by a decimal
4 years 1 month ago - 4 years 1 month ago #251447 by masterjuggler
Attached a quick demo of the spindle load bar working if that helps give motivation lol.
By the way, on a totally unrelated note, how are you supposed to configure the pin display on the status page? I see that I can edit each pin's name and the card names, but I haven't been able to find how to either set them up in the gui or add them to a config file.
EDIT: seems I can't upload a proper video, so I zipped it. Oh well.
Last edit: 4 years 1 month ago by masterjuggler.
The following user(s) said Thank You: tommylight, Lcvette
4 years 1 month ago #251448 by Lcvette
awesome!  how is the updating in realtime? is it pretty smooth?
4 years 1 month ago #251450 by masterjuggler
It seems to be updating in real time, if a bit stuttery. But it's entirely probable that's caused by the fact that I'm running LinuxCNC on an AMD Athlon x2 lol.
The following user(s) said Thank You: Lcvette
4 years 1 week ago #254812 by daveyr
I have been trying to the same as in this thread but i seem to not be able to find halcompile
For my install i used the joco-nz bullseye installer to install the dev version of probe basic and linuxcnc 2.9
I am not sure if you would be willing to share your compiled version as i also have a 9 amp max for my VFD.
4 years 1 week ago #254817 by TurBoss
Hello
To get halcompile you need to install linuxcnc-dev or linuxcnc-uspace-dev
The following user(s) said Thank You: masterjuggler
3 years 9 months ago - 3 years 9 months ago #262823 by CNC_ANDI
at
halcompile --install load_conv.comp
i get this error:
cnc@debian:~$ halcompile --install load_conv.comp Traceback (most recent call last): File "/usr/bin/halcompile", line 1556, in <module> main() File "/usr/bin/halcompile", line 1526, in main process(f, mode, outfile) File "/usr/bin/halcompile", line 1366, in process a, b = parse(filename) File "/usr/bin/halcompile", line 434, in parse f = open(filename).read() FileNotFoundError: [Errno 2] No such file or directory: 'load_conv.comp' where i can find load_conv.comp?
Last edit: 3 years 9 months ago by CNC_ANDI.
Moderators: KCJ, Lcvette
Time to create page: 0.191 seconds
