[SOLVED] Qtpyvcp - error on startup
- spumco
- Thank you received: 780
14 Jan 2023 04:24 #261878
by spumco
Replied by spumco on topic Qtpyvcp - error on startup
Edited postgui files and merged what I needed until LCNC loaded without complaining.
Still have the original axes error in terminal, resolution is still wrong in probe basic, and still cant get out of estop or turn the machine on.
Please look at the full-screen capture. Note that the terminal window and Geany look 'normal' for a 1920x1080 monitor. Look at the LCNC config window... it's wrong.
Same thign is happening to the PB screens
HTOP attached as well.
- Lcvette
- Thank you received: 679
14 Jan 2023 04:35 #261880
by Lcvette
Replied by Lcvette on topic Qtpyvcp - error on startup
post your zipped config file
- spumco
14 Jan 2023 04:43 #261881
by spumco
Keep in mind that the postgui stuff was merged quickly. Had to rename the not.0 to not.4 and comment out a couple things.
- Thank you received: 3755
14 Jan 2023 04:45 - 14 Jan 2023 04:46 #261882
YEs you are right but if you go back and look at spumco's screendump, the right side is truncated and it does not extend the full height.
My chromebook on 1092 x 1080:
Replied by rodw on topic Qtpyvcp - error on startup
@rodw it does look like it kinda fits albeit a little scrunched in places compared to the 1920x1080 display..
Last edit: 14 Jan 2023 04:46 by rodw.
The following user(s) said Thank You: Lcvette
- Lcvette
14 Jan 2023 04:50 #261883
by Lcvette
not sure why yours is reformatting, did you tweak? looks like all the buttons and widgets are resizing and i locked them from doing so in qtdesigner
- spumco
14 Jan 2023 04:55 #261884
by spumco
I haven't touched anything backstage. And it's not just the qtpyvcp screen, the LCNC config chooser is also distorted.
- Lcvette
14 Jan 2023 04:59 #261885
by Lcvette
this is 2.10? i haven't ever tried 2.10, so you are swimming in the deep end..lol
14 Jan 2023 05:01 #261886
This is only a 14" monitor so I run it at 1536 x 864 which was my first screen dump
I then changed the resolution to 1980 x 1024 for the second screen dump. the PC is not useable at this resolution as text is too small.
The main thing I noticed was the spindle sliders were wider.
I just wanted to prove a point the error on startup is a non issue
But Spumco's screen is truncated earlier in this thread.
14 Jan 2023 05:04 #261887
There is not really anything much different with 2.10 its just that 2.9 has been hived off pending release.
To build 2.9 be sure to
git checkout 2.9
- Lcvette
14 Jan 2023 05:08 #261888
by Lcvette
@rod, your screen shot is also broken like his, something is wrong with both of your PB installs it appears, something in the formatting, but what i am not sure. something is breaking the layout format. it should look like my screenshot regardless of how it opens on the screen, but would just extend beyond. so something must be off in 2.10 if both of you are on the same version. do either of you have a 2.9 you can check from a recent script install?
Moderators: KCJ, Lcvette
Time to create page: 0.119 seconds
