Probe Basic Contour ShuttlExpress
3 years 6 months ago #268956 by Mike Connelly
A search here didn't turn up anything, so, can anyone tell me if they've been able to get a ShuttlExpress working as a jog wheel in Probe Basic?
If not, any suggestions for a good simple jog wheel, either USB or hardwired to a 7i76e?
Thanks!
3 years 6 months ago #268971 by Lcvette
I have the radio style with hardwired receiver from XHC and I couldn't be happier. I just have the most basic unit and if i had my druthers, i would opt for a feedhold button and a mode change button to switch between manual and auto mode in linuxcnc. but other than that i have been extremely impressed with the performance, battery life, durability (these things feel like very high quality units and come with a high quality molded rubber protective case. feels very sturdy in your hand and not cheap like the USB models (which i also have one of). the wireless aspect is fantastic and the delay on the radio model is non-perceptible to me. i have 3 of them, one for my big mill, one for my little mill and one for my converted lathe. the lathe is the slowest and i did some hal magic to accommodate to avoid the pulse stack-up on the slower axis'. the big mill is the fastest and it runs fine at full speed with not transition from pulse to velocity mode. but wither way i have hal for both of them and can verify they work fantastic with probe basic.
www.aliexpress.com/store/group/Wireless-...otSpots_1338008129.0
3 years 6 months ago #268992 by Mike Connelly
If I don't get a direct hit on my ShuttleXpress question I'll be looking at the XHC products. Thanks for taking the time to respond, and for sharing your thoughts and experience with the XHC wireless solution. If I go that route could I ask for copies of your hal incantations?
Thanks!
3 years 6 months ago #268993 by Lcvette
Sure, it's a self contained hal file so all you need to do is do in your config folder and change the card name and input pins used.
File Name: mpg.hal
File Size:1.56 KB
3 years 6 months ago #269011 by Mike Connelly
Thank you very much!
The following user(s) said Thank You: Lcvette
3 years 6 months ago #269188 by Lcvette
Sure thing, happy to help!
Moderators: KCJ, Lcvette
Time to create page: 0.293 seconds
