Probe Basic Contour ShuttlExpress
3 years 6 months ago - 3 years 6 months ago #269206 by rodw
Sure, it's a self contained hal file so all you need to do is do in your config folder and change the card name and input pins used.
File Name: mpg.hal
File Size:1.56 KB
There are quite a few more features you can pack into the XHC 433 MHz wireless pendant. This is still a work in progress but you can make the yellow button select the correct mode, use the spare axis controls (it has 6) for overrides etc and use the top row intelligently (which I have not nailed yet)
File Name: pendant-V1.hal
File Size:5.69 KB
Last edit: 3 years 6 months ago by rodw.
2 years 1 week ago #312934 by daveyr
Not sure if it is to late but here is the Hal file that i used for my shuttle.
As a warning every now and then i would get a run away when using the outer jog wheel thing where it would just go all the way on the axis. As a result i mainly used the jog wheel in the middle and have now transitioned to a normal pendant using a 7i73 for stepping.
To make it work all you should have to do is include the HALFILE in your .ini
#Shuttle Pendant
HALFILE = shuttle.hal
The following user(s) said Thank You: tommylight, Lcvette
Moderators: KCJ, Lcvette
Time to create page: 0.214 seconds
