Help with touch off tool setter
3 years 5 months ago - 3 years 5 months ago #270931 by Dimitrios2
Hello,
 I'm new and I'm trying to use the touch off routine without success so far. I followed those steps below.
1. Home my machine
2. Unload Spindle - tool zero
3. Touching off spindle manually to tool setter
4. Input value in Spindle Zero box
5. Retract Z up to zero
6. Setting Tool Touchoff position (XY tool setter position Z 0)
7. Load a tool
8. Touchoff tool
The machine is starting the process but, when it touches the tool setter stops and I'm getting the following error.
"Probe is already tripped when starting G38.2 or G38.3 move"
What am I missing here?
​​​​​I'm using linuxcnc 2.8.4
Thanks for your help.
Last edit: 3 years 5 months ago by Dimitrios2.
3 years 5 months ago #270932 by Lcvette
It sounds like the tool setter input needs inverse signal in hal maybe?
3 years 5 months ago #270933 by Dimitrios2
Hmm, I will tested out. Thanks for your reply.
3 years 5 months ago - 3 years 5 months ago #270935 by Dimitrios2
Ok, by using the Hal Meter my tool setter is FALSE as is and TRUE when it's pressed.
This is the line that I've added to me Hal file.
"net probe parport.0.pin-11-in => motion.probe-input"
How can I invert the signal to tested it out? I've tried net probe parport.0.pin-11-in-not, didn't worked. The signal is actually inverted in hal meter but, I'm pressing the tool setter by hand and I'm not getting any response.
Or maybe this is the way supposed to be?
3 years 5 months ago #270937 by Dimitrios2
I don't think that is the pin. I if inverse the signal it triggers when it's relished and not when it's pressed.
3 years 5 months ago #270941 by Dimitrios2
I've set the back as it was an now it's working somehow! Anyways, thanks a lot for jumping into it.
Moderators: KCJ, Lcvette
Time to create page: 0.306 seconds
