Probe Basic 4th Axis plot
2 years 9 months ago #291497 by Aciera
Replied by Aciera on topic Probe Basic 4th Axis plot
You need to be on version 2.9.x for this:
However, it may not be worth the effort as the feature is rather picky regarding the work offsets and the offset values are treated as values in inches even on a metric setup.
2 years 9 months ago - 2 years 9 months ago #291534 by anton610
Replied by anton610 on topic Probe Basic 4th Axis plot
Many thanks!!
Looks good!
I'll try.
First I'll do an update.
Best regards
Anton
Last edit: 2 years 9 months ago by anton610.
2 years 8 months ago #293070 by anton610
Hello,
I'm on 2.9.2
but still no 4th axis plot.
Do i have to change anything else?
Thanks!
2 years 8 months ago #293073 by Aciera
Have you changed the 'GEOMETRY' string in the [DISPLAY] section of your ini file?
2 years 8 months ago - 2 years 8 months ago #293085 by anton610
Yes
A!XYZ
Last edit: 2 years 8 months ago by anton610.
2 years 8 months ago #293087 by Aciera
Rereading the documentation makes me wonder if the exclamation mark should be before rather than after the rotational axis letter.
Experimental: If the exclamation mark (
) character is included in the GEOMETRY string, display points for A, B, C rotations respect the X, Y, Z offsets set by G5x, G92 codes. Example: Using
GEOMETRY = !CXZ
for a machine with
[TRAJ]COORDINATES=XZC
. This provision applies for liveplots only — G-code previews should be done with zero G5x, G92 offsets. This can be facilitated by setting offsets in programs only when task is running as indicated by #<_task> == 1. If nonzero offsets exist at startup due to persistence, offsets should be zeroed and preview reloaded.
Maybe try:
!AXYZ
Moderators: KCJ, Lcvette
Time to create page: 0.358 seconds
