Tool Anzeige
  • Edi_48
  • Topic Author
  • Senior Member
  • Senior Member
2 years 7 months ago #296693 by Edi_48
Tool Anzeige was created by Edi_48
Kann man auf der Seite Tool Vermessen , die Spalten A Offset bis w Offset  ausblenden ?
beim Werkzeug einmessen  muss immer den Schieber  betätigen das man die Zeile Remark sieht.
mfg
Hilton
2 years 6 months ago - 2 years 6 months ago #297689 by Lcvette
Replied by Lcvette on topic Tool Anzeige
yes, this is setup in the custom_config.yml file in the congifs folder. you will see the tool table column letters, simply change to the ones you wish deisplayed.
the below is a section from the custom_config.yml file:
data_plugins:
    tooltable:
        provider: qtpyvcp.plugins.tool_table:ToolTable
        kwargs:
        columns: TXYZDR <
these can be edited to display your desired columns.
Last edit: 2 years 6 months ago by Lcvette.
2 years 2 weeks ago - 2 years 2 weeks ago #312653 by Jensner
Replied by Jensner on topic Tool Anzeige
after my last reinstallation of LinuxCNC + Probe Basic i run into an equal problem that in my tooltable, where normaly has been shown 3 columns (number, Diameter, Info), there are now nearly 20 columns.
I tried to solve this with the "custom_config.yml" file, but nothing changed.
Is there an detailed info how exactly to use these yml-files with Probe Basic?
Do i have to do something more to activate the yml file?
Thanks a lot..
Best regards
Jens
Last edit: 2 years 2 weeks ago by Jensner.
2 years 2 weeks ago #312692 by Lcvette
Dies the sim show correctly?
2 years 2 weeks ago #312733 by Jensner
Yesterday, i did some further testing and at least i could solve the issue with my tootlable.
Thanks to all.
Moderators: KCJ, Lcvette
Time to create page: 0.111 seconds
