probe_basic_lathe vtk_backplot.py error
2 years 1 month ago #309717 by iMaks-RS
error if open any .ngc turn file.
how to disable or change backplot to "standart" - as axis interface?
mill probe_basic - ok.
1 year 11 months ago #315024 by iMaks-RS
Updated the system today, including ProbeBasic from version 0.5.4 to version 0.6. The error is still there, but the error message is different.
Is the lathe version tested by anyone before release? If so, on what configuration?
1 year 11 months ago #315744 by Lcvette
need more information on your build, what debian version what kernel version etc... the sim here is working as expected so i would assume the issue is a compatibility problem you are experiencing perhaps or maybe the custom_config.yml file needs to be updated.
have you tested using the simulation version of probe basic?
1 year 10 months ago #316571 by Lcvette
did you resolve? did you ever test the sim? and did you check the custom_config.yml settings by comparing to the latest sim version that gets copied over? those sometimes require updating as well if transitioning from older probe basic versions.
1 year 10 months ago #317399 by iMaks-RS
rollback/downgrade to 2.8.4: install NativeCAM with Gmoccapy.
I hope that in the future I will be able to use the turning version. I would like to hope that it will also have built-in NativeCAM functionality (there is a problem now, because it does not work with python and glade version 3).
Yes, I ran the simulation and it had such errors. I am also not satisfied with ngcgui scripts and similar wizards. In my opinion, the most convenient for a "home craftsman" is either ELS + CNC. Or a CNC system that will allow you to replace ELS.
Thank you for your work and the time you devoted to the project. This is a really cool project. Unfortunately, all the projects I know are more focused on milling and the turning configuration is done on a residual principle. Perhaps I have a false picture of the world .. but this is exactly what I encountered.
(translated by Google translator)
1 year 10 months ago #317404 by Lcvette
No worries, the lathe interface does need some TLC. I'm going to be running a clean install/update on my machine to see if I can reproduce, on my test pc I could not replicate the errors you reported so makes it difficult to track down where the issue was coming from. Will report back.
What is ELS?
Moderators: KCJ, Lcvette
Time to create page: 0.231 seconds
