Question on Step 4 of the APT install instructions
2 years 1 week ago #312900 by tenfrozentoes
I'm completely new and having trouble telling what the individual commands are in the box. I think I've goofed things up, Probe Basic shows up under my configurations- but errors out. I'm feel like I've probably executed step 4 incorrectly. I now have tried a few different times/ways. Am I supposed to separate at the 'pipe' ( | ), line by line, or ?
Is it relevant to even post the error/debug info until I've completed the instructions satisfactorily?
Jim
2 years 1 week ago - 2 years 1 week ago #312903 by tenfrozentoes
Just to clarify.
The directions say: Run the following commands in the main terminal one at a time:
sudo apt install curl
echo 'deb [arch=amd64] repository.qtpyvcp.com/apt stable main' | sudo tee /etc/apt/sources.list.d/kcjengr.list
curl -sS repository.qtpyvcp.com/repo/kcjengr.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/kcjengr.gpg
gpg --keyserver keys.openpgp.org --recv-key 2DEC041F290DF85A
Im not certain what the individual commands are. It's probably obvious to most... but I'm very very new to LinuxCNC
Last edit: 2 years 1 week ago by tenfrozentoes. Reason: Visual formating
2 years 1 week ago #312904 by tsaG
You have to run the command in the main terminal line by line. So 4 commands in total.
The following user(s) said Thank You: tenfrozentoes
2 years 1 week ago #312906 by tenfrozentoes
Okay, Thankyou. That is actually what I did first but then wasnt sure, so I tried rerunning them seperatated by the | symbols. I'm going to delete the configs and redo.
Jim
The following user(s) said Thank You: Lcvette
2 years 1 week ago #312985 by Lcvette
thank you for pointing that out, i have now adjusted the docs to make it more clear with some spacing between the lines, please let me know if this would have been clearer when you first were running the install!
Thanks,
Chris
2 years 1 week ago #313004 by tenfrozentoes
Wow- Incredibly responsive!!!
Unfortunately- Im still not able to load Probe Basic. I get a PopUp of LinuxCNC Errors thats longer than a book. I've attached it here.
For what ever it is worth- I have succesfully loaded/launched qtdragon GUI ok.
The uploader yelled at me for the .report extention- so I added a .txt
Hopefully that works.
I appreciate any advice I can get.
File Name: linuxcnc.report.txt
File Size:38.3 KB
Moderators: KCJ, Lcvette
Time to create page: 0.062 seconds
