Manual Tool Change (Stable version) and tool load position
1 year 10 months ago #316914 by mkudlacek
Thank you for the ideas. I didn't want to take the approach of needing to know a precise Z height of tool setter, because it feels cumbersome to me, however beneficial it may be. And I got away with that:) So, attached is the code of my take on the manual tool change macro. It works on my machine flawlessly and I think it's rather elegant solution. The procedure is noted in the macro itself and here's excerpt of the documentation:
​​ (#####################################################################################) (        ) ( Documentation        ) (        ) ( This macro is for measuring and setting tool offset after manual change of the tool ) ( in non-ATC spindles. It ensures (via G43), that the tip of the tool will be at the  ) ( same Z-height after change. It uses a touch tool setter in known XY position. The Z ) ( position of the tool setter doesn't have to be known, nor precise. It only has to   ) ( be the same throughout the session.                                                 ) (        ) ( The macro fits the settings in Probing -> Tool Setter dialog in Probe Basic         ) ( It is meant to be used as M6 Remap:                                                 ) (        ) (     [RS274NGC]        ) (     SUBROUTINE_PATH = subroutines                                                   ) (     REMAP=M6 modalgroup=6 ngc=modorinc-tool-change                                  ) (        ) ( At the begining of a job, load the probing tool to the spindle. The tool could be   ) ( a sharp rod or anything that allows you to mark a WCS origin. The tool has to be in ) ( tool table and has to have a number specified in #<probing_tool_number>, e.g. 999.  ) ( Load the tool with M6 T999 command or via the UI.                                   ) ( The spindle will go to a location, where it is easy to load the tool, by default    ) ( G53 [X0,Y0,Z0]. If the currently loaded tool is not #999, a built-in dialog will    ) ( appear, telling you to load the tool into spindle and press button to continue.     ) ( After loading, the spindle travels to tool setter's X,Y position in Z0 height.      ) ( When it is above the tool setter, a current position stored in #5422 is remembered. ) ( Then it goes down to a Z height from which the probing starts. From there, it       ) ( initiates faster touch of the tool setter. If correct, it goes up a little bit and  ) ( repeats the touch with slower feedrate. If the second touch is correct a current    ) ( position stored in #5063 is remembered.                                             ) (        ) ( The difference between the two offsets is an absolute distance between the tool tip ) ( in Z0 and the tool setter. This value, measured with a probing tool is stored in    ) ( variable denoted by #<probing_tool_address>.                                        ) ( After successful touch-off of the probing tool, you can continue to mark the WCS    ) ( origin with it. Then start the program. The offset of the probing tool is set to 0  ) ( and all subsequent tool changes will set the offset of the new tool based on the    ) ( difference of tool tip height of the probing tool.                                  ) ( The offsets are stored into tool table via G10 L1 and activated by G43.             ) (        ) (#####################################################################################)​​​​​
1 year 10 months ago #316929 by Lcvette
sweet! looks like you had some fun playing in the subroutines! rewarding yes?
as long as it accomplishes your goals its good in my eyes! go forth and probe many tools!
Chris
Moderators: KCJ, Lcvette
Time to create page: 0.045 seconds
