Probe Basic - How does tool setter calculate ?
1 year 10 months ago #317655 by onceloved
You can watch this video
The following user(s) said Thank You: Lcvette
1 year 9 months ago #318056 by TooTall18T
When you need to measure your tools after each change, like me, you could use my subroutine (for Probe Basic up to 0.5.4: github.com/TooTall18T/tool_length_probe / for Probe Basic 0.6.0 github.com/TooTall18T/tool_length_probe/tree/develop ).
Or for Probe Basic 0.6.0 you could also do that:
M6 Tx
o<tool_touch_off> call
That starts the tool measuring routine from Probe Basic after the tool change.
For Probe Basic 0.5.4 and lower it is not that easy. I would then recommend to my routine. Otherwise you would have to maintain the settings twice.
1 year 9 months ago #318219 by Lcvette
I would recommend to only use the latest versions for fixes are pushed regularly now on them and the methods used to pass variables will work in all circumstances of call, for example in remap the parameters from the ui were not accessible, the later versions used the var file which makes them available in remap also.
Moderators: KCJ, Lcvette
Time to create page: 0.133 seconds
