Probe basic Install errors
  • gblcody
  • gblcody's Avatar Topic Author
  • New Member
  • New Member
07 Jan 2025 03:15 #318279 by gblcody
Probe basic Install errors was created by gblcody
Hey guys, I'm struggling. I am beyond frustrated with trying to get Probe Basic to launch fully. I have been trying to get this to work since a few days before Christmas.
Here is what I know.
I can launch the Dev with the sim on the PC.
I figured out that one of my issues was the screen size. I now have a compatible screen installed.
I have reinstalled the bookworm iso and followed the instructions several times.
I have cleaned and wiped the system at least 6 times and always come back to an error launching.
i was having the issue of probe basic not launching due to a ini dual hal file error but after a wipe and reinstall and apt repair it seems to have gone away.
I am still getting can not start display probe basic. I have gone through the configs several times and started fresh with my ini and hal files and still can not get it to launch via Linux CNC launcher with my setup files.
Any advice? I would greatly appreciate it.
07 Jan 2025 12:54 #318297 by tommylight
Replied by tommylight on topic Probe basic Install errors
Moved to QtPyVCP section.
07 Jan 2025 15:19 #318302 by Lcvette
Replied by Lcvette on topic Probe basic Install errors
post your config files without them there isn't any way to identify the issue(s)
  • gblcody
  • New Member
  • New Member
10 Jan 2025 04:18 #318610 by gblcody
Replied by gblcody on topic Probe basic Install errors
Lcvette, Sorry, when I wrote this originally the site was having issues and I could not post. seems I forgot to add them when I tried to post the second time.
Let me know if you need anything else!
All the help is appreciated!
10 Jan 2025 04:29 #318611 by Lcvette
Your in file has some errors
Remove the comments X'd or on red in the image below
You had calls don't match the file names, it won't fine the hall with an incorrect name, post gui is also wrong name.
10 Jan 2025 15:54 #318642 by Lcvette
for clarification, if the file names of the files you uploaded are the ones you intend to use, you need to use them in the ini file call as shown below:
[HAL]
HALUI = halui
HALFILE = probe_basic_setup_2025-01-09.hal
POSTGUI_HALFILE = probe_basic_postgui.hal
TWOPASS = on
  • gblcody
  • New Member
  • New Member
11 Jan 2025 19:22 #318699 by gblcody
Lcvette,
Thanks for the help.
I'm unsure why the file names on the forms now have the 2025-01-09 attached. It must have been added when I uploaded them. They match what I have in the ini file except for the postgui file name error. I thought I had changed that one. I have made the suggested changes and still can't launch Probe Basic. getting the error "Can't execute DISPLAY program probe_basic  "
12 Jan 2025 04:13 #318736 by Lcvette
How did you install probe basic?
12 Jan 2025 04:16 #318737 by Lcvette
If you have Facebook you can join the basic group, may be easier to troubleshoot in real-time
www.facebook.com/groups/probebasic/?ref=share&mibextid=NSMWBT
  • gblcody
  • New Member
  • New Member
12 Jan 2025 22:00 #318830 by gblcody
I first tried installing using the guide but it seems part of the links are broken. I then eventually found the script to install it on git. github.com/Lcvette/qtpyvcp-bookworm-inst...r?tab=readme-ov-file
So I installed Debian 12 and followed the steps on the git. This is where I know I can get the dev version to launch, but when I set up my machine file, it just never launches. I will join the FB group going forward.
Moderators: KCJ, Lcvette
Time to create page: 0.132 seconds
