Probe Basic Tool Setter questions
1 year 8 months ago - 1 year 8 months ago #320956 by CGT80
To set up my computer, I followed Dr. Dflo.
www.drdflo.com/pages/Projects/CNC-Mill.html#linuxcnc
Click on linuxcnc from the left menu.The last line of the paragraph has a specific link for setting up for Probe Basic, so that is what I have been following.
He lists this link: kcjengr.github.io/probe_basic/quick_start.html
From here, I downloaded the Debian 12 bookworm image (on my win 11 computer) and followed the instructions to make a bootable usb drive. I probably used the link to make the image but am not 100% sure......it was a simple utility like what is listed.
I ran that usb drive on my new computer for this mill: Intel NUC mini desktop Core i5-9300H, 8GB ram, 256 GB SSD. It removed windows and only Debian is installed.
It appears it was Debian 12.2.0, as you can see from the first commands I typed into the terminal (text file below).
I just updated Debian by using sudo apt update and sudo apt upgrade from the terminal.
It gave me an error on lines 705 and 722:
Let's see if I attached the file correctly.....
File Name: debianupdateerror.txt
File Size:74.42 KB
What does this error mean and how do I address it?
I have not yet restarted the computer, but ran the command to check the debian version and it is still 12.2.0. I will do a restart and check again.
Last edit: 1 year 8 months ago by CGT80.
1 year 8 months ago - 1 year 8 months ago #320957 by Lcvette
Try running update upgrade again, if errors are encountered, run the following
sudo apt --fix-broken install
Last edit: 1 year 8 months ago by Lcvette.
1 year 8 months ago #320961 by CGT80
After restarting, I ran
sudo apt update
sudo apt upgrade
And again, it came back with errors, so I ran
It also came back with errors:
File Name: errorafter...tall.txt
File Size:5.18 KB
This report is much shorter. Reading through it, it isn't apparent to me what is happening.
1 year 8 months ago #320962 by Lcvette
Copy each of the missing dependency names and run
sudo apt install dependencyname
once the missing deps are installed it should complete update without complaint. I've not seen that before though.. kind of odd
1 year 8 months ago #320963 by Lcvette
Sorry it looks like it's maybe missing in the kernel build.
Restart and try running again
1 year 8 months ago #320964 by Lcvette
You can also open the synaptic manager and search:
linux-image
Right click the latest rt preempt signed kernel version and select for installation. Then click apply in the top menu. See if that works
Moderators: KCJ, Lcvette
