- User Interfaces
- Other User Interfaces
- QtPyVCP
- Probe Basic no feed override slider while cycle run - solved
- Muftijaja
- Thank you received: 4
16 Feb 2025 23:28 - 18 Feb 2025 21:46 #321782
by Muftijaja
Probe Basic no feed override slider while cycle run - solved was created by Muftijaja
Hello everyone, I have another small problem again. My machine does not have an active feed slider for some time now. Normally, after start and homing, it is active but during a cycle run I cannot adjust the feed with the slider. What is the reason for this? I know that this has worked before and I don't know which setting has been lost.In the INI, I have MAX_FEED_OVERRIDE = 2.000000Does anyone know anything about this?
ChatGPT told me to add two entries in the HAL file:
net feed_override <= halui.feed-override
net motion_feed_override => motion.feed-override
I made these entries, but the machine does not start - error - halui.feed-override does not exist...
What can I do?
Thanks for every hint!
Greets, Hanno
What can I do?
Greets, Hanno
Last edit: 18 Feb 2025 21:46 by Muftijaja.
- Lcvette
- Thank you received: 784
17 Feb 2025 00:22 #321786
by Lcvette
Replied by Lcvette on topic Probe Basic no feed override slider while cycle run
For the UI you do not need that, it's coded and the only setting is the ini. You may have a conflict if using an external source besides the screen sliders. I would remove any external source and check if functionality on screen returns.
Also try the sim to verify it still has functioning override sliders.
The following user(s) said Thank You: Muftijaja
- TooTall18T
- Thank you received: 37
17 Feb 2025 20:03 #321863
by TooTall18T
Replied by TooTall18T on topic Probe Basic no feed override slider while cycle run
I found the reason for this. He's using my tool probe routine and I forged two lines in it.
The following user(s) said Thank You: Lcvette, Muftijaja
- Lcvette
18 Feb 2025 00:14 #321882
by Lcvette
Ah.. gotcha
- Muftijaja
18 Feb 2025 21:33 - 18 Feb 2025 21:34 #321943
by Muftijaja
Replied by Muftijaja on topic Probe Basic no feed override slider while cycle run
Hello TooTall18T!
I tested the V.5.01 and voila - it works as it should and the Feed Override Slider is active again! Thank you for detecting that problem in your routine and fixing it finally! You are my hero, my machine is now ready for the first chips. (not really, but mainly)
Thanks a lot,
Hanno
Thanks a lot,
Hanno
Last edit: 18 Feb 2025 21:34 by Muftijaja.
- Lcvette
19 Feb 2025 16:37 #321998
by Lcvette
excellent news!
Moderators: KCJ, Lcvette
- User Interfaces
- QtPyVCP
Time to create page: 0.132 seconds
