config tool setter
10 Apr 2025 15:07 - 10 Apr 2025 15:07 #326038 by Ismacr63
config tool setter was created by Ismacr63
I'm having a problem with the tool setter configuration. I don't know if it's just me or if it's a known problem, although I haven't found anything similar on the forum.
When I modify a tool setter parameter, I click "update tool setter parameters" and it's saved. When I close Probe Basic and reopen it, the configuration changes to the previous one, and spidnle in the var file is reset to zero.
As a result, the milling machine has already crashed several times, until I realized that for some reason the configuration was out of order.
I'm also getting the error shown in one of the images when I turn Probe Basic on and off.
The error in the image shows the tool setter settings I entered, and the other image shows the settings that are set when I close and reopen Probe Basic.
I'm on the stable branch.
Last edit: 10 Apr 2025 15:07 by Ismacr63.
11 Apr 2025 23:34 #326131 by Lcvette
Replied by Lcvette on topic config tool setter
Post your var file
The following user(s) said Thank You: Ismacr63
12 Apr 2025 09:38 - 12 Apr 2025 09:44 #326154 by Ismacr63
Replied by Ismacr63 on topic config tool setter
Here I attach the var file.
Last edit: 12 Apr 2025 09:44 by Ismacr63.
01 May 2025 13:17 #327429 by Lcvette
did you get this resolved?
04 May 2025 20:48 #327710 by Ismacr63
Unfortunately not.
I updated Probe Basic and created a new configuration, but the problem isn't resolved.
I tried changing spindle zero in SIM, and it does retain the spindle zero value.
06 May 2025 23:31 #327913 by Lcvette
Double check you have the correct subroutines for the latest update.
11 May 2025 20:53 #328230 by Ismacr63
I updated everything again and created a new configuration.
Now the spindle zero value is saved in the var file, but in Probe Basic, after closing and reopening it, it shows the value 0, but the value I entered remains in the var file.
If I enter a value of 227.0000mm, for example, the value always remains in both the var file and the interface. However, if I enter 227.5456, it is saved in the var file, but then it appears as 0 in the interface.
22 May 2025 02:27 #328885 by Lcvette
So your saying the decimal format creates the disappearing value?
23 May 2025 20:47 #329016 by Ismacr63
yes that's how it is.
25 May 2025 06:20 #329089 by Lcvette
i cannot replicate, i get the value stored in both the var and the ui even through multiple restarts it remains correct.
Moderators: KCJLcvette
Time to create page: 0.289 seconds
