I have a part that I need to probe. The Z is from the bottom of the part, as the thickness is very important. So I want to probe Z prior to probing the edges (corner) of the part as the part will cover the Z (top of fixture /bottom of part). I know I can do the corner first, remove the part then probe z, but that requires to put the part back in the same X-Y postion.
