Probe Basic Stable error
9 months 1 week ago #341672 by ncf250sd
I just updated to the stable version of probe basic, installed using the APT stable install and running Linuxcnc 2.9.8.  During testing I have most functions working; however, I get the following error when I click on the "go to home" and the "go to zero" buttons. "Named parameter #<geomery> not defined" The error message is the same for both buttons.  Any suggestions on this error?
9 months 1 week ago #341673 by Lcvette
Replied by Lcvette on topic Probe Basic Stable error
It's telling you that you have not defined everything required for that function in the initial file.
kcjengr.github.io/probe_basic/machine_config.html
9 months 1 week ago #341674 by ncf250sd
Replied by ncf250sd on topic Probe Basic Stable error
Yep, that was it, thank you. Somehow I missed the AXES=3. Another question, my E stop button stays bright red the entire time, it still works. It just never changes from red to shaded.
9 months 1 week ago #341676 by Lcvette
Check you hardware estop configuration
9 months 1 week ago #341811 by ncf250sd
a quick follow-up on the E stop. I checked everything on my side that I could think of and the light stays on. I just upgraded from the original PB where the E stop button worked as it should. Maybe I was not clear with my issue. When I activate my e stop on my pendant the screen E stop light goes off. However if i push the screen E stop button the machine stops but the button stays on. You think its still on my side?
9 months 1 week ago #341911 by Lcvette
the on screen button and physical button cannot remain synchronized as the screen cannot physically change the mushroom buttons state. so you will need to add in some hal NOT allowing the UI estop button in probe basic to be in a state different from the physical mushroom button.
Moderators: KCJ, Lcvette
