- Thank you received: 3
Probe Z offset
- Estley
- Topic Author
2 months 2 days ago #349361
by Estley
Probe Z offset was created by Estley
Apologies for the use of improper terminology, newbie here. So, I have a PrintNC machine with Probe Basic. For the most part the setup has been intuitive, and most of the questions i've had have already been answered here. The one thing I'm a bit confused about is probing, I have a tp06 probe, and I've been using it to find corners, bosses, bores etc. So one of the settings is the tip diameter of the probe, which is perfectly clear to me as to why it's needed. The one thing I cant figure out is, isn't the height of the probe also needed? In my mind, i can bring the spindle (no tool) down until it touches the spoilboard, and record the Z height at the point (Z0). Then I cant put the probe in the spindle, and lower it until the spindle touches the spoil board and record that Z (Z1). From there the probe offset is Z0-Z1 (or the other way around), My question is, where do i configure that probe offset? is it a variable in the .var file?
- dbtayl
- Thank you received: 36
2 months 2 days ago #349364
by dbtayl
Replied by dbtayl on topic Probe Z offset
I don't know if Probe Basic does it differently, but the probe I use with the Axis UI is configured as a tool in the tool table. The length offset then gets applied like every other tool
2 months 2 days ago #349370
Replied by rodw on topic Probe Z offset
yeh, pretty sure its the same as qrdragon. Define your probe as a tool and record the height as you would any other tool, I used T99 for the probe.
- Estley
- Topic Author
2 months 2 days ago #349372
by Estley
Replied by Estley on topic Probe Z offset
Ah, it sounds pretty obvious once you think about it. Thanks!
- Lcvette
- Thank you received: 782
2 months 21 hours ago #349435
by Lcvette
Replied by Lcvette on topic Probe Z offset
correct probe is stored tool with a z offset required and you also need to run the calibration to configure the trigger distance if you have not already done so.
Moderators: KCJ, Lcvette
Time to create page: 0.142 seconds
