GCode viewer line numbers
- persei8
- Thank you received: 133
13 Mar 2020 12:49 #160064
by persei8
GCode viewer line numbers was created by persei8
The current gcode_editor widget only allows a line number margin width of 5 characters. 2d carving files often have more than 100K lines. What's the best way to change this to 6 characters? Thanks.
- bbsr_5a
- Thank you received: 106
13 Mar 2020 13:43 #160066
by bbsr_5a
Replied by bbsr_5a on topic GCode viewer line numbers
best way woudt be reduce the lines of g-code by increasing the linewidth
or even a greater Tool
this needs to be done as of a programmer in the QTWidget
- Thank you received: 2181
13 Mar 2020 13:44 - 13 Mar 2020 17:40 #160067
Replied by cmorley on topic GCode viewer line numbers
I just pushed work - it should be one character wider now and if you want to change it after that then use something like this:
self.w.GCODEEDITOR_WIDGET_NAME.set_margin_width(8)
This is new so you need to pull it in before trying it.
Chris
Chris
Last edit: 13 Mar 2020 17:40 by cmorley.
- phillc54
- Thank you received: 2100
13 Mar 2020 23:32 - 13 Mar 2020 23:42 #160124
by phillc54
Edit: I see it just got pushed to master with my last update.
Replied by phillc54 on topic GCode viewer line numbers
I don't see this yet.I just pushed work - it should be one character wider now and if you want to change it after that then use something like this:
Last edit: 13 Mar 2020 23:42 by phillc54.
13 Mar 2020 23:58 #160127
Thats twice now where I merged and then didn't push --getting older faster...
- phillc54
14 Mar 2020 00:28 #160133
by phillc54
Quick question, is it possible to set the color and background in the stylesheeteditor. I have tried a few things but didn't get anywhere.
I only need it for when I am trying different things and do something wrong they end up the same color.
I know the feeling well...Thats twice now where I merged and then didn't push --getting older faster...
14 Mar 2020 01:12 #160136
I haven't tried stylesheets on gcode editor - i'll see what i can findout. My guess is it's controlled by the editor because of text coloring for different code.
- phillc54
14 Mar 2020 01:25 #160137
by phillc54
Not the GCode Editor (although that would be nice as well) the StyleSheetEditor itself.
Sometimes I change something in the StyleSheetEditor and end up with the same color and background...
14 Mar 2020 02:17 #160139
ok try this:
StyleSheetEditor, QTextEdit {
background-color: lightblue;
color:green;
- phillc54
14 Mar 2020 02:31 #160142
by phillc54
Thanks Chris, the QTextEdit without the StyleSheetEditor works well enough to keep me out of trouble.
Time to create page: 0.665 seconds
