LCDNumber
30 Sep 2021 12:19 - 30 Sep 2021 17:31 #221887 by partec
LCDNumber was created by partec
does it miss correct configuration or may it be an issue, please?
when using    generalhalinput    how could it in handler.py be coded, please?
every beginning is difficult, Chris, I've found a newer environment, now it's slowly but surely a lot of fun
This also works flawlessly, now I'm working on converting a former pyvcp to your very sophisticated qtvcp applications, many thanks to all the brownies!
Last edit: 30 Sep 2021 17:31 by partec.
01 Oct 2021 02:29 #221933 by cmorley
Replied by cmorley on topic LCDNumber
Sorry i didn't get to answer you sooner - but you found the answer - hopefully the docs helped a bit...
General input/output is used for connecting HAL events to widgets or vice versa in a general way using slot/signals in designer.
It's probably better if you can use a purpose built widget if it's available.
Chris
The following user(s) said Thank You: partec
01 Oct 2021 02:57 #221935 by cmorley
I didn't read carefully - I see you got the LCD widget to display floats - I'll add some more info in the docs!
01 Oct 2021 05:12 #221938 by cmorley
In master I added some docs and new abilities to LCDNumber.
Chris
The following user(s) said Thank You: tommylight, partec
01 Oct 2021 16:48 #221973 by partec
Replied by partec on topic LCDNumber
thank you Chris, everything works really well, at the moment i'm still pretty busy with the adaptation of the pyvcp-panel to the qtvcp-panel maybe i can then give a little experience report
02 Oct 2021 16:05 #222029 by partec
After starting the panel, all slider values show zero even though the start setting is somewhere in the middle
only after each individual slider has been touched and moved minimally are the appropriate values output immediately
02 Oct 2021 20:21 #222046 by cmorley
i fixed it in master - I see dial did the same too.
thanks for bring this to my attention.
03 Oct 2021 13:22 - 03 Oct 2021 13:26 #222102 by partec
thank you Chris, how can i get this fixed files from master, please?
then i tried today to install a new clean system for running designer -Qt5 but sadly without success
DEBIAN BUSTER LINUX 2.8.2 Xfce iso Jun 27 2021
$ uname -a
   Linux vre 4.19.0-17-rt-amd64 #1 SMP PREEMPT RT Debian 4.19.194-3 (2021-07-18) x86_64 GNU/Linux
LinuxCNC 2.8.2-11-g6a3d0a434
$ sudo apt-get install qttools5-dev-tools
$ sudo apt-get install qttools5.dev
(from here was Qtvcp panel already running)
$ /usr/lib/python2.7/dist-packages/qtvcp/designer/x86_64/qt5.9/libpyqt5_py2.so.tar.gz
first i tried with   [ln -s /path/to/original /path/to/link]
ln -s /usr/lib/python2.7/dist-packages/qtvcp/plugins/qtvcp_plugin.py ~/.designer/qtvcp_plugin.py
ln -s /usr/lib/python2.7/dist-packages/PyQt5 ~/.designer/PyQt5
but result in designer no linuxcnc widgets visible
then i made this two links with "sudo thunar" as hard links to the files and moved to the places
Last edit: 03 Oct 2021 13:26 by partec.
03 Oct 2021 18:07 #222124 by cmorley
I didn't realize you were using 2.8 - I backported the code to it.
should be available from the buildbot soon.
For designer qtvcp widgts to work in 2.8 the lib libpyqt5.so must be removed or renamed to make sure libyqt5_py2.so is found first
03 Oct 2021 20:31 #222131 by partec
thank you Chris, well, I thought it would be okay to work with iso 2.8 installation, but may be as a pretty old man I should learn something again
at the moment i have renamed the libpyqt5.so
and then also removed
but there must be another error, no linuxcnc widgets are loaded
Time to create page: 0.263 seconds
