How to select qtdragon_hd?
15 Nov 2021 05:08 #226540 by ucancallmebob89
How to select qtdragon_hd? was created by ucancallmebob89
@cmorley
Looks like I'm running Linuxcnc 2.8.2. Do I need to upgrade to 2.9 to get access to qtdragon_hd?
15 Nov 2021 05:33 #226541 by ucancallmebob89
Replied by ucancallmebob89 on topic How to select qtdragon_hd?
OK! So upgrading to linuxcnc 2.9 allowed me to select the qtdragon_hd screen. This youtube video was helpful for doing the upgrade
Now I need to figure out how to select dark mode.
15 Nov 2021 05:36 #226542 by cmorley
Replied by cmorley on topic How to select qtdragon_hd?
Excellent! press f12 - it brings up the stylesheet selector
15 Nov 2021 05:59 #226544 by ucancallmebob89
https://photos.app.goo.gl/4TbkUWbkvyeZoCab7Perfect! I assume a lot of these buttons are greyed out b/c I'm not currently connected to my machine? I brought the PC inside the house to troubleshoot.
15 Nov 2021 06:02 #226545 by cmorley
yes you are not out of estop/machine on/homed - ,most keys will be grayed out
10 Dec 2021 03:38 #228752 by ucancallmebob89
@cmorley thanks for all your help so far.
I'm seeing some weird behavior when trying to set up my touch plate. Here's the procedure I'm following:
  • Measure the touch plate height with calipers and enter it under SETTINGS > TOUCH PLATE HEIGHT (it's 19.12mm)
  • Connect alligator clip to bit and put touch plate under the bit within 20mm
  • Press TOUCH PLATE button
  • The Z axis moves down until the bit contacts the touch plate, then backs off slightly
At this point I expected that the Z coordinate would be set to the height of the touch plate + the back off distance, but it doesn't seem to be doing that. Any idea what's going on here? What script is this button referencing so I can do more debug?
Also, what is the WORKPIECE HEIGHT field in the OFFSETS section used for?
10 Dec 2021 10:53 #228769 by cmorley
First off, I'll disclose that I didn't make qtdragon so I don't always know perfectly the intentions of behavior.
Saying that - My understanding is after probing, the G54 Z setting should set zero at the bottom of the touch plate.
(so yes just as you thought)
workpiece height is used with sensor height when using a tool height sensor probe.
You can look at the python code here:
github.com/LinuxCNC/linuxcnc/blob/ca4317...n_hd_handler.py#L904
(I do see some problems if using imperial mode with probing)
Chris
10 Dec 2021 11:17 #228771 by cmorley
I do see an apparent error with probing...
line 923 is not right - that is the lift up move to reprobe - but it returns without reprobing.
It would leave the machine at 4mm above the last probe - which is pretty close to what your image shows.
Chris
10 Dec 2021 12:11 #228772 by cmorley
I have pushed a fix for this. HD now uses the same routine as qtdragon and should work properly (and in metric or imperial)
10 Dec 2021 12:14 #228773 by cmorley
In case you are still interested, the probe routine is here:
github.com/LinuxCNC/linuxcnc/blob/ec64ae...ff_subprogram.py#L54
Time to create page: 0.240 seconds
