Probe Basic rapids
- natholego11
- Thank you received: 4
16 Feb 2022 17:27 #235053
by natholego11
Probe Basic rapids was created by natholego11
Good afternoon,
I noticed while running a program that the rapids seems stuck at 60ipm, my machine is capable of running faster than that (and does when it uses a G1 as a rapid movement instead) but when a G0 is commanded it only runs at 60.
Ive attached a screen shot of what I am seeing in my INI and on the GUI
- Thank you received: 2147
17 Feb 2022 04:52 #235095
Replied by cmorley on topic Probe Basic rapids
Can you move this to qtpyvcp section?
You might get a proper response there as the basic probe devs will get an email.
Chris
Chris
- natholego11
17 Feb 2022 12:25 #235127
by natholego11
Replied by natholego11 on topic Probe Basic rapids
Can I do that as just a member? I dont see a place to move topics.
- Thank you received: 7384
17 Feb 2022 12:28 #235128
Thank you.
Replied by tommylight on topic Probe Basic rapids
Done.Can you move this to qtpyvcp section?
Thank you.
- Lcvette
- Thank you received: 755
17 Feb 2022 17:56 #235152
by Lcvette
Replied by Lcvette on topic Probe Basic rapids
can you post your whole ini file for us?
- natholego11
17 Feb 2022 18:05 #235153
by natholego11
this isnt the latest, but its close enough, im not at my machine at the moment.
- Lcvette
17 Feb 2022 18:14 - 17 Feb 2022 18:14 #235155
by Lcvette
Last edit: 17 Feb 2022 18:14 by Lcvette.
- Lcvette
17 Feb 2022 19:00 #235157
by Lcvette
it is in inches per second, so setting of 1.0 inch/sec = 60 ipm should help figure out your desired max speed, but typically will match what you have higher up in the ini file from the pncconfig output think yours was 4.0 which is 240ipm
- natholego11
18 Feb 2022 11:58 #235229
by natholego11
worked Perfectly, Thank you!
Moderators: KCJ, Lcvette
Time to create page: 0.153 seconds
