qdragon.var file from PYTHON
4 years 8 months ago - 4 years 8 months ago #236128 by Mduran
Some way to use the parameters of the qdragon.var file from Python code in the same way that they can be declared from MDI (example: #4000 = 60)
Last edit: 4 years 8 months ago by Mduran.
4 years 8 months ago #236147 by andypugh
I think you could probably just read the file into a string and parse it.
(I would probably use regex)
4 years 8 months ago #236152 by cmorley
I'm not exactly sure how you want to use the varfile data.
You can, qtvcp widget origin_offsetview does this.
You must be careful when you read/write to it as linuxcnc does not monitor it for external changes and only syncs the file at specific times.
