Untimely alarm information
07 Mar 2022 05:00 - 07 Mar 2022 05:53 #236561 by yi2580
Untimely alarm information was created by yi2580
I found that when I was using it, the pop-up error message here was not very timely. I think there is a pile of error messages here. Sometimes the first error message will be displayed when there are four or five errors
Last edit: 07 Mar 2022 05:53 by yi2580.
07 Mar 2022 05:10 #236564 by cmorley
Replied by cmorley on topic Untimely alarm information
isn't there buttons to show the last 5 messages?
07 Mar 2022 05:24 #236565 by yi2580
Replied by yi2580 on topic Untimely alarm information
It will be displayed, but it is not real-time enough. For example, there is an error message for the sixth time, but what he displays here is a secondary error message
07 Mar 2022 14:13 #236579 by tommylight
Replied by tommylight on topic Untimely alarm information
uname -a
08 Mar 2022 02:31 #236624 by cmorley
can you run linuxcnc from a terminal and see if more errors show in the terminal?
Or if the errors are in a different order.
11 Mar 2022 02:54 #236911 by yi2580
Errors are also displayed in the terminal, but the prompt box here is not displayed in time. It seems that error messages are piled up, and he will have four or five message delays. Or is there an error message refresh statement
11 Mar 2022 16:06 #236942 by cmorley
Can you give more detail?
Do all the messages in the terminal make it to the window but in a different order?
From memory the window will limit the messages to the last 5.
I guess the other question is how many error messages are you getting and trying to display?
14 Mar 2022 00:45 #237174 by yi2580
No, the order of error reporting is correct, but it is not displayed in time. For example, it should have five errors now, but only one error is displayed
14 Mar 2022 02:38 #237181 by cmorley
What screen are you using?
What would you like to happen?
What do you have so many errors to process?
Usually as an operator you clear errors as they come and they shouldn't come often.
Of course if your screen uses custom code you can catch them with your own code.
Also I am assuming you are not using any other program that reads linuxcnc's errors?
Having more then one program read linuxcnc errors is a no no.
16 Mar 2022 03:32 #237426 by yi2580
OK, thank you very much for your reply. There is another question. Can there be a way to get rid of the alarm prompt in this pop-up window?
