- Thank you received: 7
QTdragon settings disappeared
4 years 6 months ago #240549
by myval
QTdragon settings disappeared was created by myval
I am just having monster headache. I finished machining yesterday turned the machine off today I turned it on and all the qt dragon settings are reset to default including probe calibration.
I am running latest Linuxcnc and QtDragon_HD
4 years 6 months ago #240552
Replied by tommylight on topic QTdragon settings disappeared
Check the config folder, usually there are config files that have been copied and extension changed to bak or similar.
But first, why you do not have a zipped and backed up config folder? Takes about 5 seconds. Copy to USB another 2 minutes.
Back on topic, copy the folder somewhere else before changing the extensions and testing, use the text editor to figure out what might be the good config and what not.
And do mind what is changed or moved or renamed.
4 years 6 months ago #240553
by myval
Replied by myval on topic QTdragon settings disappeared
Hey Tommy I checked config folder. All linuxcnc files are backuped but not the qtdragon.pref
I know idiot I had old backup but I am still tweaking stuff and just did not do it.
Probably good idea if qtdragon create backups by itself for idiots like me.
4 years 6 months ago #240636
Replied by cmorley on topic QTdragon settings disappeared
I could probably add a backup file mechanism in the future.
Strange that it didnt dave properly though.
Are you using master branch or 2.8 branch?
4 years 6 months ago #240865
by myval
Hi, I am using the latest-ish 2.9.
It just happened again. attached is a log if anyone wants to have a look.
4 years 6 months ago #240868
Change the memory, hard drive and/or power supply.
If that keeps happening it is a sure sign one of them is failing, in that order.
Although there is always the possibility of the memory or hard drive controllers to fail, and they are on the mother board.
Time to create page: 0.270 seconds
