QtDragon Utilities ????
4 years 5 months ago #243178 by Roguish
Is anyone working on any additional Utilities for QtDragon?
single hole drilling?
boring?
rigid tapping?
Just curious.
4 years 5 months ago #243182 by cmorley
Replied by cmorley on topic QtDragon Utilities ????
No others that I know of.
Jim adapted Ngcgui to qtvcp recentlyits in the utilities tab.
Also now you can embed qtvcp qtvcp panels into the utilities tab.
The following user(s) said Thank You: Roguish
4 years 5 months ago #243193 by Roguish
Replied by Roguish on topic QtDragon Utilities ????
Thanks Chris.
is any of that in docs?
if so, where? i don't see it.....
also, I would like to add an LED or something for limit switches.
LED? or what?
also, I don't see the limits in halglib.
but of course they are in hal pins, could you give a little direction.... please.
4 years 5 months ago #243242 by cmorley
embedding:
linuxcnc.org/docs/devel/html/gui/qtdrago...ed_custom_vcp_panels
NGCGui is mentioned but with no detail.
It works similarily as the original NGCGui though the process is slightly different. If you know NGCGui you should be able to figure it out. I have not had time to thoughly test it. Jim (qtdragon's creator) built it.
hardlimits are tracked by STATUS (AKA halGlib) as 'hard-limits-tripped' message
status image switcher can change images in a label based on hard limits.
If you want simple LED indicators, I could add it to the state LED widget.
Chris
4 years 5 months ago #243280 by Roguish
thanks again Chris.
i'll look through the doc link you gave.
for the limits, I saw the -tripped in halglib, but could not see individual trips.
I would like to see the individual limits. an LED would be totally adequate.
If you could add them that would be cool. maybe the homes while you're at it.
Let me know when you get it done and so I can look over the widget and see how ya do it.......
cheers.
4 years 5 months ago #243315 by cmorley
Ok, state_led now has properties:
neg_hard_limit_state
pos_hard_limit_state
hard_limits_state
(don't forget to select the joint number too)
Home is already there:
is_joint_homed_status
Time to create page: 0.054 seconds
