- Thank you received: 17
Auto-populate Tabs in Qtdragon NGCGUI?
- Eyecon
- Topic Author
4 years 3 months ago #248859
by Eyecon
Auto-populate Tabs in Qtdragon NGCGUI? was created by Eyecon
Hello,
Not sure if I'm missing something or if this feature is just not implemented yet: using NGCGUI_SUBFILE in the INI file doesn't seem to work with the qtvcp version of NGCGUI. I looked at the ngcgui class constructor in the python module and I don't see where ini settings are being read but I could be wrong as I'm not sure how this is all supposed to work. Am I missing something?
- Thank you received: 2181
4 years 3 months ago #248889
Replied by cmorley on topic Auto-populate Tabs in Qtdragon NGCGUI?
It doesn't look like Qts version looks for NGCGUI_SUBFILE.
It looks for SUBROUTINE_PATH under the RS274NGC heading.
I take it NGCGUI looks in NGCGUI_SUBFILE?
I'm sure that can be added.
- Eyecon
- Topic Author
4 years 3 months ago #248890
by Eyecon
Replied by Eyecon on topic Auto-populate Tabs in Qtdragon NGCGUI?
Yes according to the ngcgui docs and that’s how pyngcgui works in other UIs. I have subroutine path properly defined in my INI but I’m not sure it does anything. Even the qtdragon sim files have the path defined but nothing seems to load by default.
- persei8
- Thank you received: 133
4 years 2 months ago #249715
by persei8
Replied by persei8 on topic Auto-populate Tabs in Qtdragon NGCGUI?
I will look into adding auto population of tabs to qtdragon. Thanks for the feedback.
Jim
Jim
- Eyecon
- Topic Author
4 years 2 months ago #249723
by Eyecon
I already contributed the code and Chris was kind enough to clean it up and integrate it into master
- persei8
4 years 2 months ago #249730
by persei8
Yes, but I'm going to add it to my github source which Chris has stated that he will eventually use to update the sim configuration.
The following user(s) said Thank You: tommylight, Eyecon
Time to create page: 0.050 seconds
