Probe Basic in QTDragon
3 years 10 months ago #260597 by cmorley
Replied by cmorley on topic Probe Basic in QTDragon
I think these routines are shared by probe basic and versa probe. Ill look into it.
Thank you.
3 years 9 months ago #260785 by Carsten
Replied by Carsten on topic Probe Basic in QTDragon
Happy New Year,
we have the x-axis north/south and the y-axis east/west, hence the scripts does not match the buttons.
Currently I renamed the files and the functions in them in my macros directory.
As I understand the assigment of function to button is done in basic_probe.ui.
I don't want to modify "delivered" files.
Is there a way to use a custom basic_probe.ui? I tried it parallel to my qtdragon.ui and in the macros directory, but both didn't work.
Kind regards
Carsten
3 years 9 months ago #260832 by cmorley
Unfortunately completely overriding widget files is not supported, if that is what you mean.
It possible to class patch imported widgets in the handler file.
linuxcnc.org/docs/2.9/html/gui/qtvcp-cod..._file_manager_widget
or you could make a custom qtdragon ui/handler file that uses a custom basic_probe.widget.
I would think using the handler file to delete the stock basic probe widget then import and inject a custom version would be the easiest.
The code was changed alot in 2.9 so I'm a little unfamiliar with the 2.8 code. I'll look when I have a bit of time.
3 years 9 months ago #260914 by Carsten
Thanks for the info.
There is no need to bother with old code. I stick to my renamed files.
I have some proposals for the probe_*.ngc files:
1. z_clearance and xy_clearance are used both for slow probing (to save time I want it small) and for safety distance (I want it larger).
    My proposal: use clearance for safety distance only and hard code the pull back for slow probe to 2 mm.
2.1. For all probe_*outline.ngc and probe_corner*.ngc you must have executed probe_z_minus_wco.ngc (center button) to get the correct height of the probe (I rammed my probe into the floor as I forgot it)
=> call probe_z_minus_wco in all probe_*outline.ngc and probe_corner*.ngc first.
2.2. To make the lowering of the probe beside the workpiece more safe use G38.3 instead of G1.
3. Error in probe_front_left_outside.ngc: in line 72 you must move X #<xy_clearance> + #<step_off_width>, because probe_x_plus ends in -#<xy_clearance>.
Attached you will find my probe_z_minus_wco.ngc and probe_front_right_outside.ngc (which is the originally probe_front_left_outside.ngc) and diff files.
Kind regards
Carsten
The following user(s) said Thank You: Roguish
3 years 9 months ago #263038 by cmorley
I just added some work that would allow you to use a custom ui file for the basic probe/versa probe widgets. that might be enough for you to change the button controls.
let me know if you would like more details (and would require the latest code in 2.9/master)
2 years 2 months ago #307573 by Carsten
Hi Chris,
I upgraded to 2.9.3 and would appreciate a hint how to use a custom iu file.
Kind regards
Carsten
Time to create page: 0.105 seconds
