MDI error while Probing
4 years 1 month ago - 4 years 1 month ago #251159 by MoshKopp
I`m playing aroung with QTDragon_HD for the probing Tab I use basic_probe. on Lcnc bullseye 2.9 pre.
If I run for e.g. Z- Probing. Z sometimes drive 2mm sometimes less, sometimes more.
in debug he writes
2022-09-04 06:04:32,362 - QtDesigner.QTVCP.QT_ACTION - DEBUG - CALL_MDI Command: G91 2022-09-04 06:04:32,383 - QtDesigner.QTVCP.WIDGETS.PROBE_ROUTINES - DEBUG - MDI_WAIT_COMMAND= G38.2 Z-10.0 F250.0, maxt = 30 2022-09-04 06:04:32,383 - QtDesigner.QTVCP.QT_ACTION - DEBUG - CALL_MDI Command: G38.2 Z-10.0 F250.0 2022-09-04 06:04:33,531 - QtDesigner.QTVCP.WIDGETS.PROBE_ROUTINES - ERROR - MDI_COMMAND_WAIT Error channel: Aborted command 2022-09-04 06:04:33,592 - QtDesigner.QTVCP.QT_ACTION - DEBUG - CALL_MDI Command: G90
is there a way to search why MDI is interrupted?
Last edit: 4 years 1 month ago by MoshKopp.
4 years 1 month ago #251172 by persei8
Replied by persei8 on topic MDI error while Probing
This error says the command timed out, meaning it took longer than 30 seconds. How far from the workpiece was the probe tip when you started the probe? At 250 mm/min it will time out if the distance is more than 125 mm. Not sure what you mean by Z sometimes driving 2 mm. Do you mean it only goes 2 mm and then shows the error?
Jim
4 years 1 month ago #251174 by MoshKopp
Replied by MoshKopp on topic MDI error while Probing
I'm short over the Object, maybe 4mm, he drives maybe 1 second.
sometimes a bit longer. and if I have many Luck he makes 1 one time contact, retract, and stops before second measure.
if it helps I can try make a video or something else.
4 years 1 month ago #251185 by cmorley
Replied by cmorley on topic MDI error while Probing
This doesn't give enough info from the terminal - it's a catch all error message.
If it timed out there would be a specific one.
I wonder if the probe is picking up interference or miss tripping?
4 years 1 month ago #251212 by MoshKopp
I solved that Problem with reinstalling LinuxCNC. now it works.
I dont know why.
But ran into the same Problem like in the other Post where MaxXY dist. is MaxZ dist.
4 years 1 month ago #251242 by cmorley
Remind me of the other post please. link?
Time to create page: 0.123 seconds
