MDI error while Probing
4 years 1 month ago - 4 years 1 month ago #251159
by MoshKopp
MDI error while Probing was created by MoshKopp
I`m playing aroung with QTDragon_HD for the probing Tab I use basic_probe. on Lcnc bullseye 2.9 pre.
If I run for e.g. Z- Probing. Z sometimes drive 2mm sometimes less, sometimes more.
in debug he writes
is there a way to search why MDI is interrupted?
in debug he writes
2022-09-04 06:04:32,362 - QtDesigner.QTVCP.QT_ACTION - DEBUG - CALL_MDI Command: G91
2022-09-04 06:04:32,383 - QtDesigner.QTVCP.WIDGETS.PROBE_ROUTINES - DEBUG - MDI_WAIT_COMMAND= G38.2 Z-10.0 F250.0, maxt = 30
2022-09-04 06:04:32,383 - QtDesigner.QTVCP.QT_ACTION - DEBUG - CALL_MDI Command: G38.2 Z-10.0 F250.0
2022-09-04 06:04:33,531 - QtDesigner.QTVCP.WIDGETS.PROBE_ROUTINES - ERROR - MDI_COMMAND_WAIT Error channel: Aborted command
2022-09-04 06:04:33,592 - QtDesigner.QTVCP.QT_ACTION - DEBUG - CALL_MDI Command: G90
Last edit: 4 years 1 month ago by MoshKopp.
4 years 1 month ago #251172
by persei8
Replied by persei8 on topic MDI error while Probing
This error says the command timed out, meaning it took longer than 30 seconds. How far from the workpiece was the probe tip when you started the probe? At 250 mm/min it will time out if the distance is more than 125 mm. Not sure what you mean by Z sometimes driving 2 mm. Do you mean it only goes 2 mm and then shows the error?
Jim
Jim
4 years 1 month ago #251174
by MoshKopp
Replied by MoshKopp on topic MDI error while Probing
I'm short over the Object, maybe 4mm, he drives maybe 1 second.
sometimes a bit longer. and if I have many Luck he makes 1 one time contact, retract, and stops before second measure.
if it helps I can try make a video or something else.
4 years 1 month ago #251185
Replied by cmorley on topic MDI error while Probing
This doesn't give enough info from the terminal - it's a catch all error message.
If it timed out there would be a specific one.
I wonder if the probe is picking up interference or miss tripping?
4 years 1 month ago #251212
by MoshKopp
I solved that Problem with reinstalling LinuxCNC. now it works.
I dont know why.
But ran into the same Problem like in the other Post where MaxXY dist. is MaxZ dist.
I dont know why.
4 years 1 month ago #251242
Remind me of the other post please. link?
Time to create page: 0.262 seconds
