A few issues with the qtdragon (Linuxcnc 2.9)
4 years 1 month ago #252981 by cmorley
yes it seems calibration does calculates the delta, not automatically start using it.
But I'm still seaching..
The following user(s) said Thank You: Eyecon
4 years 1 month ago #252982 by Eyecon
Thanks Chris, yes set rotation angle does set the rotation but it seems to set the xy zero to the location of the last probed point regardless of what specific edge rotation routine is selected. What's getting me confused is the graphics on that page seem to indicate that the zero XY points should be the first point it probes(indicated but the green target icon). I guess "auto zero" should not be selectable when "set rotation angle" is selected because the behaviour I've been observing with both buttons toggled on is that XY is reset to machine zero.
4 years 1 month ago #252983 by cmorley
Ok yes in the code X and Y will always be zero for basic probe:
G10 L2 P0 X0 Y0 R (whatever)
There is a note that 'data_adj_x' etc used in the rotate coordinate function is versa probe only.
4 years 1 month ago #252984 by cmorley
I think qtdragon's basic probe is based on pyqtvcp's 'basic probe' screen.
You might gleam some insight if they have docs on the probe routines.
then we can fill in the blancks in the docs and help screen.
Thanks for poking me to look at the code.
4 years 1 month ago #252991 by Eyecon
yes I figured but unfortunately it's not documented either as far as I can tell. Really appreciate your help Chris!
4 years 3 days ago #255360 by cmorley
Working on some more docs for basic probe, maybe you could comment.
here is what I got so far:
Basic probe is used to semi-automatically probe workpieces to find edges, centers and angles. The combo box allows selecting the basic type of probing buttons shown: * Outside Corners * Inside Corners * Edge Angles * Boss and Pockets * Ridge and Valleys * Calibration You must carefully set the 'Probing Parameters': * 'Probe Tool': will only allow probing if this tool number is in the spindle * 'Probe Diameter': the size of the probe tip * 'Probe Rapid': the speed of rapid moves in machine units * 'Probe Search': the speed of the first 'rough' search in machine units * 'Probe Feed': the speed of the second 'fine' search in machine units * 'Extra Depth': Lowers the probe further by this much * 'Step Off': back off and reprobe distance * 'Max XY Distance': the maximum distance the probe will search for in X and Y * 'Max Z Distance':  the maximum distance the probe will search for in Z * 'XY Clearance': move away distance from probed point before rapid traversing in X and Y * 'Z Clearance': move away distance from probed point before rapid traversing in Z * 'Edge Width': approximate distance the probe start position is from edge There are also hint parameters depending on selected probing type: * 'Diameter Hint': used by Round Boss or Round Pocket probing (moves 1/2 diameter plus XY clearance) * 'X Hint': used by Rectangular Boss/Pocket probing (moves 1/2 X length plus XY clearance) * 'Y Hint': used by Rectangular Boss/Pocket probing (moves 1/2 Y length plus XY clearance) After setting the parameters, manually move the probe to the approximate position represented by the purple circle on the button. Confirm the parameters are reasonable then press the desired probing button. The probing routine will start immediately.
The following user(s) said Thank You: tommylight, Eyecon
Time to create page: 0.065 seconds
