qt5 no module named '_hal'
30 Jan 2023 13:37 #263235 by HiSH
qt5 no module named '_hal' was created by HiSH
When starting qt5 in a terminal, there are no linuxcnc widgets and after closing qt5, there is following error:
File "/usr/lib/python2.7/dist-packages/hal.py, line 30, in <module>
ModuleNotFoundError: No modules named '_hal'
A file '_hal.py' didn't exist and i don't know why. How can i eleminate this error?
31 Jan 2023 07:20 #263305 by cmorley
Replied by cmorley on topic qt5 no module named '_hal'
Seems to be a python version problem.
What version of linuxcnc are you using?
31 Jan 2023 09:46 #263326 by HiSH
Replied by HiSH on topic qt5 no module named '_hal'
It is LinuxCNC V2.8.4 .
01 Feb 2023 02:52 #263415 by cmorley
what do you see in the folder:
/usr/lib/x86_64-linux-gnu/qt5/plugins/designer
01 Feb 2023 07:55 #263424 by HiSH
sorry, the i try to send the image as attachment.
02 Feb 2023 04:25 #263493 by cmorley
Ok the file libpyqt5.so is most likely the python3 version, you need the python2 version.
you need to find out the qt version you are using, if you open designer and look in ABOUT qt, it should tell you - something like 5.7.1 version.
This is the readme that explains the problem:
github.com/LinuxCNC/linuxcnc/blob/2.8/li.../designer/README.txt
There is a file 'install_script' that can be run to automate the changes:
It should be here on your system:
/usr/lib/python2.7/dist-packages/qtvcp/designer/install_script
02 Feb 2023 10:08 #263510 by HiSH
Thank you. Unfortunately i could not find the libraries descripted in the readme file, just as the "install-script" in the folder, you told me.
Where can i get from, respectively is it necessary to install something else?
The qt5 designer i had installed, as described in the readme file.
03 Feb 2023 02:22 #263567 by cmorley
Are you using an installed version of linuxcnc or a compiled version?
Which files are missing?
Did you find the script?
Is there a folder here: /usr/lib/python2.7/dist-packages/qtvcp/ ?
06 Feb 2023 08:13 #263804 by HiSH
It was a .ISO with 2.8.2 and later updated to 2.8.4.
The folder "/usr/lib/python2.7/dist-packages/qtvcp" exists with:
cnc@LinuxCNC:/usr/lib/python2.7/dist-packages/qtvcp$
core.py
logger.py
qt_istat.pyc
qt_pstat.pyc
test1.ui
core.pyc
logger.pyc
qt_makegui.py
qt_tstat.py
widgets
designer
plugins
qt_makegui.pyc
qt_tstat.pyc
__init__.py
qt_action.py
qt_makepins.py
qtvcp_handler.py
__init__.pyc
qt_action.pyc
qt_makepins.pyc
qtvcp_handler.pyc
lib
qt_istat.py
qt_pstat.py
README.txt
The folder "/usr/lib/python2.7/dist-packages/qtvcp/designer" exists too with:
README.txt
x86_64
Is it necessary to install or download something else?
07 Feb 2023 02:18 #263889 by cmorley
Here is the script:
github.com/LinuxCNC/linuxcnc/blob/2.8/li...igner/install_script
should go in /usr/lib/python2.7/dist-packages/qtvcp/designer
and run from there.
Time to create page: 0.240 seconds
