QtDragon GUI QTvcp ERROR! Message # 1
18 Feb 2023 14:16 - 18 Feb 2023 14:17 #264751 by Dragonick
QtDragon GUI QTvcp ERROR! Message # 1 was created by Dragonick
Hi, I have a problem with qtdragon.
I have linux 2.9 master and tried to install qtdragon_hd.
However, I get an error just like in the picture.
What am I doing wrong?
Last edit: 18 Feb 2023 14:17 by Dragonick.
18 Feb 2023 16:03 #264757 by cmorley
Replied by cmorley on topic QtDragon GUI QTvcp ERROR! Message # 1
Looks like you are using master not 2.9.
Can you run linuxcnc in a terminal and post any output?
posting your config files might be helpful too please.
20 Feb 2023 15:17 #264869 by Dragonick
Replied by Dragonick on topic QtDragon GUI QTvcp ERROR! Message # 1
I installed 2.8.4 buster from iso. Later I upgraded to master. ( my mistake i took the example from the 2.9 update video )
then I installed Python 3.7, Qt 5 and then Install QtPyVCP. I had to manually install pip3 numpy because some error popped up.
When I open via CNC-LinuxCNC-sim.qtdragon_hd then it starts. One when I created the configuration via Stepconf and rewrote all the data as in the example:
linuxcnc.org/docs/devel/html/gui/qtdragon.html
this pops up the error seen in the first post.
Can you tell me how to post any output to you?
If I type linuxcnc in the terminal, this is what I get:
20 Feb 2023 18:26 #264889 by cmorley
You can just copy and paste the output into the forum.
20 Feb 2023 19:28 #264892 by Dragonick
Did you mean this?
File Name: linuxcnc.txt
File Size:14 KB
20 Feb 2023 19:38 #264893 by cmorley
ok ya that shows a hint.
If I understand correctly, it's a configuration that you have editted that does not run properly?
Now I need to see your configuration files. Archive them and post them here please.
20 Feb 2023 19:52 #264895 by Dragonick
File Name: mill2.zip
File Size:7 KB
20 Feb 2023 20:54 #264901 by cmorley
Fir some reason milltask is not finishing initialization in time.
Also the debug messages have weird symbols that make me wonder of python version problems.
Can you run a version that works and post the terminal output for it?
20 Feb 2023 21:28 #264906 by hottabich
Replied by hottabich on topic QtDragon GUI QTvcp ERROR! Message # 1
File Size:7 KB
Look at the screenshots, maybe it will help you.
20 Feb 2023 21:46 #264907 by cmorley
The Qtdragon error is not the real problem. It shows because linuxcnc didn't initialize properly.
Time to create page: 0.647 seconds
