QTDragon MDI jogging strange - diagonals
- frayja2002
- Thank you received: 13
28 Feb 2023 08:12 #265535
by frayja2002
QTDragon MDI jogging strange - diagonals was created by frayja2002
Hi all
I having some strange behaviour from the QTDragon MDI.
If i start QTDragon, home all axis & then use this sequence of commands I get something strange.
G0 X10
G0 Z100
G0 Y10
G0 Y100
The first commands work normally but when I enter the G0 Y10 the X axis also moves (back to X10). Each time I type a command after that the axis move diagonally.
I have tried the Axis screen &Â Gmoccapy & they both seem to work as expected.
I am using the latest build bot on Buster 10 - LINUXCNC - 2.10.0-pre0-928-gf1ce19ba4
Is there something I am missing here?
All help appreciated.
Alex
G0 X10
G0 Z100
G0 Y10
G0 Y100
Alex
- Thank you received: 2181
28 Feb 2023 13:50 #265562
Replied by cmorley on topic QTDragon MDI jogging strange - diagonals
Is this using the sim config or a real machine?
My test here on a sim works fine.
- persei8
- Thank you received: 133
28 Feb 2023 16:27 #265577
by persei8
Replied by persei8 on topic QTDragon MDI jogging strange - diagonals
Well this is peculiar. I can confirm the same behaviour as the OP describes on both my development version (which is technically a simulation) and the linuxcnc sample config (sim.qtdragon_hd.qtdragon_hd_xyz). However, my real machine, which has the exact same software as my development machine, works perfectly. I also confirmed that mdi_line.py wasn't submitting incorrect data to the ACTION.CALL_MDI command. I'm assuming the reference to Z100 in the OP's post was a typo and should be X100. Either way, it happens with Z moves too.
Jim
Jim
- frayja2002
28 Feb 2023 20:58 #265613
by frayja2002
Replied by frayja2002 on topic QTDragon MDI jogging strange - diagonals
Yes What you'r saying is correct it should have been an X.
I have tried this on an actual running machine and (after) on the XYZ sim.
Alex
Alex
01 Mar 2023 02:30 #265629
I see it now.
i also you can get all three axis to move with:
g0 x something
g0 y something
g0 z something
then g0 any of them all three will move.
but if I jog X axis with the on screen buttons, then I can G0 X anywhere and only X will move.
But if I mdi another axis it will move both again.
g0 x something
g0 y something
g0 z something
- JohnnyCNC
- Thank you received: 115
01 Mar 2023 03:16 #265630
by JohnnyCNC
Replied by JohnnyCNC on topic QTDragon MDI jogging strange - diagonals
I'll give this a try on my machine tomorrow.
01 Mar 2023 03:45 #265632
I have found the problem line of code.. working on the best solution.
01 Mar 2023 04:04 #265633
In case your interested:
In mdi_line.py the display is reloaded when MDI commands are run.
During reloading the display, the task_plan_synch() is called, seemingly out of order.
Probably gets called before the MDI finishes, so old positions are used to update.
The following user(s) said Thank You: eduard
01 Mar 2023 05:24 #265634
Ok I pushed a hopeful fix to 2.9 and master.
Please let me know if it fixes things for you.
- frayja2002
01 Mar 2023 08:05 #265637
by frayja2002
Hi there
As said in the initial post I'm using buildbot (2.10)
Should I be seeing an update. When I try to do an update it tells me all packages are up to date.
Will this normally come through prity quickly.
Alex
Alex
Time to create page: 0.153 seconds
