- Thank you received: 3
QTdragon and basic probe
- Drillbit
- Topic Author
3 years 7 months ago #267900
by Drillbit
QTdragon and basic probe was created by Drillbit
I feel stupid for asking but how to get this tab in my qtdragon.
linuxcnc.org/docs/devel/html/gui/qtdragon.html#_basic_probe
I saw some git repos and and an installer that seems to use older phyton libraries, however seeing its in the main documentation I am assuming something easier allows it to be installed.
For some reason I'm struggling to get the basics of how the UI can be changed. As it took so long to get things running kind of afraid of breaking things as well, i.e probably less open to experimenting. So appreciate any help.
Extra info if needed -
I have the tool touch off working fine to get the z height. But would like the x and y as well.
I am also hoping that this will also change the default tool change code, at the moment I have to split the g files for each tool change as I use a collet but that would be a bonus.
- Thank you received: 2181
3 years 7 months ago #267913
Replied by cmorley on topic QTdragon and basic probe
- Drillbit
- Topic Author
3 years 7 months ago #267935
by Drillbit
Replied by Drillbit on topic QTdragon and basic probe
Phython-dev is no longer available since Debian 11 from what I can see.
"sudo apt install python-pyqt5 python-pyqt5.qtquick python-dbus.mainloop.pyqt5 python-pyqt5.qtopengl python-pyqt5.qsci python-pyqt5.qtmultimedia python-pyqt5.qtwebkit qml-module-qtquick-controls gstreamer1.0-plugins-bad libqt5multimedia5-plugins pyqt5-dev-tools python-dev python-setuptools python-pip git:"
fails.
fails.
- Drillbit
- Topic Author
3 years 7 months ago #267938
by Drillbit
Tried a few other things like the installer instead of the dev install. However it uses python in its commands. When I try to manually do the commands making them python 3 it starts talking about being a managed environment and to use pipx.
Well lost.
What I really need is
sudo apt install phython3-basicprobe
Sorry for not knowing what I'm doing or having a totally different setup to what is expected.
Well lost.
3 years 7 months ago - 3 years 7 months ago #267940
Did you try the INI entries I pointed to?
Qtvcp's Basic probe is already included.
Note not to be confused with 'probe basic' which is a pyqtvcp screen.
Last edit: 3 years 7 months ago by cmorley.
The following user(s) said Thank You: Drillbit
- Drillbit
- Topic Author
3 years 7 months ago #267963
by Drillbit
Had loads of tabs open and printed the wrong one. Sorry. My mistake.
- Drillbit
- Topic Author
3 years 7 months ago #267968
by Drillbit
How did I miss that file. Its perfect, all the things I've been struggling with.
Time to create page: 0.163 seconds
