[SOLVED] QtDragon - Spindle at speed LED not working
- karnalta
- Thank you received: 11
31 Oct 2023 09:32 - 01 Nov 2023 15:19 #284162
by karnalta
[SOLVED] QtDragon - Spindle at speed LED not working was created by karnalta
Hello all,
I have wired my VFD spindle at speed pin to the input 10 of my 7i96S mesa board.
The pin work correctly when monitored in HAL Show.
In my HAL file I have declared it like so :
net spindle-at-speed spindle.0.at-speed <= hm2_7i96s.0.inm.00.input-10
But in the QtDragon UI, the At Speed LED turn on immediately at spindle startup.
I am probably missing something ?
Thank for help.
Last edit: 01 Nov 2023 15:19 by karnalta.
- Thank you received: 4150
31 Oct 2023 10:14 #284168
Replied by rodw on topic QtDragon - Spindle at speed LED not working
I think you need to
net spindle-at-speed => some-qtdragon-pin-for-at-speed
check the docs.
check the docs.
- karnalta
31 Oct 2023 10:29 #284170
by karnalta
linuxcnc.org/docs/devel/html/gui/qtdragon.html#_hal_pins
Replied by karnalta on topic QtDragon - Spindle at speed LED not working
I was thinking as you but did not find anything here :I think you need to
check the docs.
- Thank you received: 2181
31 Oct 2023 12:47 #284180
Replied by cmorley on topic QtDragon - Spindle at speed LED not working
Do you have a spindle speed feedback pin connected?
Qtdragon calculates spindle at speed it's self using spindle request and spindle feedback.
Can you post your config?
- karnalta
31 Oct 2023 13:22 #284182
by karnalta
Here is relevant part of my config :
No I don't, my VFD is set to feedback a digital signal when at speed.Do you have a spindle speed feedback pin connected?
# SPINDLE IO
net spindle-enable spindle.0.on => hm2_7i96s.0.ssr.00.out-00 => hm2_7i96s.0.pwmgen.00.enable
net spindle-cw spindle.0.forward => hm2_7i96s.0.ssr.00.out-01
net spindle-ccw spindle.0.reverse => hm2_7i96s.0.ssr.00.out-02
net spindle-output-rpm spindle.0.speed-out-abs => hm2_7i96s.0.pwmgen.00.value
# SETUP MESA BOARD
# General
setp hm2_7i96s.0.pwmgen.pwm_frequency 20000
setp hm2_7i96s.0.pwmgen.pdm_frequency 6000000
setp hm2_7i96s.0.watchdog.timeout_ns 5000000
setp hm2_7i96s.0.dpll.01.timer-us -50
setp hm2_7i96s.0.stepgen.timer-number 1
setp hm2_7i96s.0.inm.00.input-10-slow 1
# Spindle
setp hm2_7i96s.0.pwmgen.00.output-type 1
setp hm2_7i96s.0.pwmgen.00.scale 24000
net spindle-manual-cw halui.spindle.0.forward
net spindle-manual-ccw halui.spindle.0.reverse
net spindle-manual-stop halui.spindle.0.stop
01 Nov 2023 05:35 #284236
you can try this.
add the file into your config folder
add this line to the INI under the [DISPLAY] setting:
USER_COMMAND_FILE = CONFIGFOLDER/qtdragonrc.py
This should make the led automatically follow the pin spindle.0.at-speed state
01 Nov 2023 05:44 #284237
save the file as qtdragonrc.py
- karnalta
01 Nov 2023 11:55 #284248
by karnalta
Here is my full qtdragonrc.py file because you already helped me out in another thread
I have no error or warning but it does not work.you can try this.
print('\nUser command file for button hiding found\n')
# needed to instance patch
# reference: https://ruivieira.dev/python-monkey-patching-for-readability.html
import types
# import the handlerfile to get reference to it's libraries.
# use <screenname>_handler
import qtdragon_hd_handler as SELF
# add hook to hide buttons
self.w.action_flood.hide()
self.w.btn_ref_laser.hide()
self.w.btn_laser_on.hide()
# add hook to bind at-speed to pin
def before_loop__(self):
try:
self.w.led_at_speed.setProperty('follow_halpin_state',True)
self.w.led_at_speed.setProperty('halpin_name','spindle.0.at-speed')
self.w.led_at_speed. _hal_init()
except Exception as e:
pass
# Here we are instance patching the original handler file to add a new
# function that calls our new function (of the same name)
# defined in this file
self.before_loop__ = types.MethodType(before_loop__, self)Please Log in or Create an account to join the conversation.
01 Nov 2023 12:43 #284249
Sorry yes dragon_hd has a different name for the led.
change all references of 'self.w.led_at_speed' to 'self.w.hal_led_atspeed'
- karnalta
01 Nov 2023 15:18 #284264
by karnalta
Thank you.
Yep, working fine nowSorry yes dragon_hd has a different name for the led.
Thank you.
Time to create page: 2.188 seconds
