I just had a play with the files and removing the soft links with no joy.
The only file in the directory containing the name "handler" is the new one you supplied.
So just to check I've done things right:
-downloaded the file from the browser (could use curl if that's an issue)
-moved the orig file out of that directory to a temporary spot (mv qtdragon_hd_handler.py ~/.)
-moved the downloaded file to that directory with the same name as the orig: qtdragon_hd_handler.py
Looking at the tail of the file I download doesn't look complete but I've not done any python - just started readying the doco.
cam@linuxcnc-mill:/usr/share/qtvcp/screens/qtdragon_hd$ tail qtdragon_hd_handler.py
self.w['btn_{}'.format(i)].setObjectName(i)
self.w['btn_{}'.format(i)].setProperty('isManSensitive',True)
self.w['btn_{}'.format(i)].hal_init(HAL_NAME=i)
self.w['btn_{}'.format(i)].setSizePolicy(QSizePolicy.Fixed, QSizePolicy.Fixed)
self.w['btn_{}'.format(i)].setMinimumSize(66, 50)
STATUS.connect('spindle-control-changed', lambda w, num, state, speed, upto,obj= self.w['btn_{}'.format(i)]: obj.setEnabled(not state))
self.w.horizontalLayout_40.addWidget(self.w['btn_{}'.format(i)] )
self.w.btn_atc_release.setText('TOOL\nRELEASE')
self.w.btn_atc_cw.setText('ATC\nCW')
self.w.btn_atc_ccw.setText('ATC\nCCW')
[/code]
And this the directory content
[code][code]cam@linuxcnc-mill:/usr/share/qtvcp/screens/qtdragon_hd$ ls -al
total 824
drwxr-xr-x 3 root root 4096 Feb 17 16:49 .
drwxr-xr-x 17 root root 4096 Sep 21 17:52 ..
-rw-r--r-- 1 root root 12232 Feb 3 09:35 argentium.qss
-rw-r--r-- 1 root root 9694 Feb 3 09:35 brushed_metal_color.qss
-rw-r--r-- 1 root root 10086 Feb 3 09:35 dark_grey.qss
-rw-r--r-- 1 root root 9210 Feb 3 09:35 dark.qss
drwxr-xr-x 3 root root 4096 Feb 10 19:50 images
-rw-r--r-- 1 root root 4304 Feb 3 09:35 metal.qss
-rw-r--r-- 1 root root 3625 Feb 3 09:35 qtdragon_hd_ABOUT
-rw-r--r-- 1 cam cam 2109 Feb 16 20:54 qtdragon_hd_handler.py
-rw-r--r-- 1 root root 1758 Feb 3 09:35 qtdragon_hd.qrc
-rw-r--r-- 1 root root 10653 Feb 3 09:35 qtdragon_hd.qss
-rw-r--r-- 1 root root 743323 Feb 3 09:35 qtdragon_hd.ui
-rw-r--r-- 1 root root 398 Feb 3 09:35 version.txt
[/code][/code]
