QtDragon bug?
2 years 7 months ago #295236 by faeluke
QtDragon bug? was created by faeluke
The location of the tool setter uses metric coordinates even though the machine is in inches
## Here are the steps I follow to reproduce the issue:
1. Start Linux Cnc
2. Enable the machine
3. Home the machine
4. Click on the "Offsets" tab
5. Click on "Go to Sensor"
## This is what I expected to happen:
The machine should move to Tool Sensor at X=5.05, Y=105.25
## This is what happened instead:
The machine moves to coordinates (approximate) X =0.196, Y=4.144
## Observations and corrective actions:
Manually changing the values on the screen to X=5.05 x 25.4 and Y = 105.25 *25.4 and the machine moved to the correct position
## It worked properly before this:
N/A
## Information about my hardware and software:
* The machine needs to be in Inches to reproduce the problem
* I am using this Linux distribution and version (often, shown by `lsb_release -a`): Mint-Cinnamon Debian 12 BookWorm
* I am using this kernel version (shown by `uname -a`): preempt-rt
* I am running A binary version from linuxcnc.org
* I am using LinuxCNC version 2.9.2
Install was accomplished using the instructions here linuxcnc.org/docs/2.9/html/getting-start...etting-linuxcnc.html
* I am using the qtDragon/Versaprobe user interface
* I am using Mesa interface hardware
I know it is requested to provide system setup files. If the problem can not be reproduced, I will gladly provide them.
2 years 7 months ago #295246 by rodw
Replied by rodw on topic QtDragon bug?
If the machine units are in inches, how do you expect it to know you want to move in metric units?
How do you tell the mechine to use metric units with your toolsetter?
Surely the correct approach is to change your offsets to be in imperial units
I don't think this is a bug.
2 years 7 months ago #295248 by faeluke
Replied by faeluke on topic QtDragon bug?
Sorry to be confusing, but the machine is using my values that are in inches as if they are metric values.
I provided 5 inches, the machine moved (5/ 25.4) = .198"
I provided 105 inches and the machine moved (105/254) = 4.144"
I had to type rather large values in the dialog box to get the machine to move to the correct position.
2 years 7 months ago #295249 by rodw
Please post your hal and ini files
2 years 7 months ago #295253 by faeluke
Thanks for your interest in this issue!
File Name: Frank.ini
File Size:5.56 KB
File Name: qtdragon.pref.txt
File Size:3.96 KB
The INI file has the correct coordinates so that the M6 remap works
The picture shows the values that had to be edited on the screen to position the tool head over the sensor.
The QT dragon preferences file shows the location that agrees with the screen.
In an attempt to be clear, the OFFSETS screen will not work if I put the correct units in inches.
It works with the values that have been converted to mm.
The M6 remap goes to the correct position given the values in the INI file.
My point is that the screen clearly indicates inches as the unit of measure, but requires the units to be in mm.
Do you agree?
If you spot any other errors, help would be greatly appreciated. image missing /media/kunena/emoticons/smile.png
I am about to start on auto tool change.
2 years 7 months ago #295267 by rodw
Seems odd. The docs say it uses machine units (inches in your case) Can you check your gcode and remap files don't issue a G21?
I will leave this one for Chris M
Time to create page: 0.066 seconds
