Can I embeded Vismach into Qtvcp ?
2 years 3 months ago #305827 by timaer
Hi,everyone.
     I'm developing a cnc control panel using Qtvcp,and I need to display the vismach 3d model and movement in the qtvcp UI interface,but I dont know how to make it ,does anyone help me how to make vismach 3d model and movement in qtvcp's UI interface (not popup window),thank you
2 years 3 months ago #305829 by Aciera
The following user(s) said Thank You: timaer
2 years 3 months ago #305831 by cmorley
Have you seen the docs?
linuxcnc.org/docs/stable/html/gui/qtvcp-vismach.html
Also the sample configurations qtdragon_metric or qtdragon_inch show vismach models in the utilities tab.
2 years 3 months ago #305838 by timaer
Thanks,but what I need is using vismach in my full customized qtvcp control pannel (which is controlled by an UI file and a handler.py)
2 years 3 months ago #305839 by timaer
Thanks,but I'm using full customized qtvcp (using .ui file and handler.py),so ,not very fitable .
2 years 3 months ago #305855 by cmorley
Are you using screen_options widget in your screen?
You can use that to load panels from INI definitions.
The docs show you how to load one programically.
