qtdragon modify
1 year 11 months ago #315699 by csurimilan
qtdragon modify was created by csurimilan
Hello,
im struggling with the modification of qtdragon. I just replaced 2 buttons. Im able to use the new design and works almost everything well. The 2 new butttons are not working. I tried with the costum_postgui.hal but i got always an errror that this pin is not valid.So i checked in qtdragon via hallshow which pins are avalibel and i didnt found my button (action_air). i searched everywhere but i dont find anything like that. (Not even action_flood and that is working well)I wanted to search for the iocontroll but that is a executable file and i cant open it. (well, im not that familiar with linux).
I hope someone can help or give me some suggestions.
1 year 11 months ago #315701 by cmorley
Replied by cmorley on topic qtdragon modify
Posting your modifications would be helpful :)
1 year 11 months ago #315711 by csurimilan
Replied by csurimilan on topic qtdragon modify
File Name: newDesign.rar
File Size:1.05 MB
1 year 10 months ago - 1 year 10 months ago #315759 by cmorley
try checking (property) Indicator_hal_pin option.
You can also set the hal pin name (property: pin_name), other wise it will use the widget name.
Last edit: 1 year 10 months ago by cmorley.
1 year 10 months ago #315771 by csurimilan
its not working.
I named my pin_name "air" and checked the indicator_HAL_pin_option as well and its not showing me anything in the hallshow under qtdragon.
if i try to make this command
net coolant-air => qtdragon.air
its telling me the same error, that such a name does not exist.
1 year 10 months ago #315849 by cmorley
Ok can you run linuxcnc in a terminal and post the output.
Also what version of linuxcnc are you using?
Time to create page: 0.356 seconds
