qtdragon modify
1 year 10 months ago - 1 year 10 months ago #315944 by csurimilan
Replied by csurimilan on topic qtdragon modify
i found a alternative.
It wokring but not like the mist and flood Buttons. (If estop is not hit i cant use the flood and the mist buttons until i hit the estop and i turn on the mschine. Well in my solutions i can turn on even the estop is not hit. But i can live with that)
I saw something interesstin according to mist or flood in the .UI file.
 <property name="mist_action" stdset="0">
  <bool>true</bool>
</property>
I didnt found anywhere "mist_action", only in .ui file. So i guess it is something implemented somewhere and thats why it was not wokring my setup with "air_action" because its anywhere implemented (in linuxcnc).
Maybe do you have any idea where could i find the "mist_action"
Last edit: 1 year 10 months ago by csurimilan.
1 year 10 months ago #316073 by cmorley
Replied by cmorley on topic qtdragon modify
If you set the 'isOnSensitive' property, then the button will be disabled until the machine is on.
The mist button uses the mist_action property.
The following user(s) said Thank You: csurimilan
Time to create page: 0.064 seconds
