- Thank you received: 27
cam_align
1 year 10 months ago #316481
by partec
Chris, a little something here, regarding the variation of the circle diameter
mouse scroll only - scroll circle diameter
may now work a little slower than in previous versions
It would perhaps be practical if the currently set value according to the
middle mouse single click - cycle through rotation increments
would also be used to adjust the diameter?
1 year 10 months ago #316561
Here is a version that use a sequence to change the diameter increment.
hold left button double click right button increment + .5
hold right button double click left button increment - .5
See if you like that. If not, yes we could just use the rotation increment for the diameter increment too.
This file must be named 'camview_widget.py' and replace the original file.
The following user(s) said Thank You: partec
1 year 10 months ago - 1 year 10 months ago #316565
by partec
unfortunately it doesn't work with this file at the moment?
File "/usr/lib/python3/dist-packages/qtvcp/widgets/camview_widget.py", line 80, in __init__
self.SUB = str.maketrans("0123456789", "â‚€â‚Â₂₃₄₅₆₇₈₉")
ValueError: the first two maketrans arguments must have equal length
both variants would be practical, but for me it would be even better to use the set rotation angles
Last edit: 1 year 10 months ago by partec.
Time to create page: 0.266 seconds
