QTDragon_hd won't display a larger file.
- matasbuk
- Thank you received: 3
14 Mar 2025 08:42 - 14 Mar 2025 08:43 #323896
by matasbuk
QTDragon_hd won't display a larger file. was created by matasbuk
Last edit: 14 Mar 2025 08:43 by matasbuk.
- Thank you received: 2181
15 Mar 2025 00:04 #323972
Replied by cmorley on topic QTDragon_hd won't display a larger file.
try adding to the INI:
[DISPLAY]
GRAPHICAL_MAX_FILE_SIZE = 40
[DISPLAY]
The following user(s) said Thank You: matasbuk
- matasbuk
21 Mar 2025 17:15 #324436
by matasbuk
Replied by matasbuk on topic QTDragon_hd won't display a larger file.
Is 40 the size in megabytes or something else?
21 Mar 2025 17:22 - 22 Mar 2025 05:02 #324437
Yes mb. -1 will give unlimited.
Eventually an extremely large program will take forever to load.
Last edit: 22 Mar 2025 05:02 by cmorley.
- matasbuk
22 Mar 2025 09:22 #324528
by matasbuk
What about 100-120mb programs? Are they possible? LinuxCNC seems to crash then loading those.
- looping
- Thank you received: 10
22 Mar 2025 15:24 - 22 Mar 2025 15:55 #324557
by looping
Replied by looping on topic QTDragon_hd won't display a larger file.
I have something similar but my file is not even big : 80k. (attached)
The bottom indicator says "LOADING 100%"
My display freeze, but the mouse cursor still move. VerNum on my keyboard is unresponsive. But I can connect with ssh.
dmesg is full of:
dmesg is full of:
[ 288.508935] nouveau 0000:01:00.0: DRM: skipped size 0000000000000000
[ 288.509728] nouveau 0000:01:00.0: DRM: skipped size 0000000000000000
[ 288.510420] nouveau 0000:01:00.0: DRM: skipped size 0000000000000000
[ 288.515551] nouveau 0000:01:00.0: DRM: skipped size 0000000000000000
[ 288.516120] nouveau 0000:01:00.0: DRM: skipped size 0000000000000000
[ 288.517095] nouveau 0000:01:00.0: DRM: skipped size 0000000000000000
[ 288.517650] nouveau 0000:01:00.0: DRM: skipped size 0000000000000000
[ 288.518745] nouveau 0000:01:00.0: DRM: skipped size 0000000000000000
[ 288.523254] nouveau 0000:01:00.0: DRM: skipped size 0000000000000000
Last edit: 22 Mar 2025 15:55 by looping.
- looping
22 Mar 2025 16:07 #324559
by looping
The complete dmesg is more interresting as there a mention about qtvcp
[ 160.876803] nouveau 0000:01:00.0: DRM: skipped size 0000000000000000
[ 160.877509] nouveau 0000:01:00.0: DRM: skipped size 0000000000000000
[ 213.991546] nouveau 0000:01:00.0: gr: intr 00100000 [ERROR] nsource 00010000 [DMA_VTX_PROTECTION] nstatus 04000000 [PROTECTION_FAULT] ch 4 [00109000 qtvcp[1515]] subc 7 class 4097 mthd 1824 data 16002556
[ 213.991571] nouveau 0000:01:00.0: gr: intr 00100000 [ERROR] nsource 00010000 [DMA_VTX_PROTECTION] nstatus 04000000 [PROTECTION_FAULT] ch 4 [00109000 qtvcp[1515]] subc 7 class 4097 mthd 1f08 data 38ff8189
[ 213.991602] nouveau 0000:01:00.0: gr: intr 00100000 [ERROR] nsource 00010000 [DMA_VTX_PROTECTION] nstatus 04000000 [PROTECTION_FAULT] ch 4 [00109000 qtvcp[1515]] subc 7 class 4097 mthd 1680 data 054d6000Please Log in or Create an account to join the conversation.
22 Mar 2025 16:28 #324561
22 Mar 2025 16:31 #324563
There are commands to help with large preview by hiding some of it:
linuxcnc.org/docs/devel/html/gui/qtdragon.html#_preview_control
i have no experience with very large programs.What about 100-120mb programs? Are they possible? LinuxCNC seems to crash then loading those.
- looping
22 Mar 2025 18:07 #324575
by looping
I'm not really surprised that this isn't related to my file, as I created it the same way I always do. I finally got it to load, but I'm not sure how. I tried kernels 6.1.0-28 and 6.1.0-32. I also tried 2.9.4-19-gd3a1da65b7, same result as with 2.10.0-pre0.
Now I have the same issue with the next file.
I will try on another hardware
Time to create page: 0.267 seconds
