Manual Toolchange + Abs Z Probe (QtDragon)
1 year 5 months ago - 1 year 5 months ago #328910 by SanzuiWorks
MennilTossFlykune
Thank you for your advice.
I've been focusing on incorporating this all day today, but I still can't get out of the error. To be honest, I don't even know where I am now.
Last edit: 1 year 5 months ago by SanzuiWorks.
1 year 5 months ago - 1 year 5 months ago #328922 by SanzuiWorks
I’ve managed to detect WCS (G54–G59) from a loaded .ngc file and output it to the terminal.
To be precise, it prints the WCS to the terminal log.
But I haven’t yet succeeded in sending it to MDI to change the GUI WCS.
Code implemented inside qt5_graphics.py > StatCanon:
def set_g5x_offset(self, index, x, y, z, a, b, c, u=None, v=None, w=None): g5x = { 1: "G54", 2: "G55", 3: "G56", 4: "G57", 5: "G58", 6: "G59", 7: "G59.1", 8: "G59.2", 9: "G59.3" } print(f"[DEBUG] {g5x.get(index)} on line {self.lineno}") super().set_g5x_offset(index, x, y, z, a, b, c, u, v, w)
Sample G-code:
G21 G90 G55 G0 X10 Y10 M2
Terminal output:
[DEBUG] G54 on line 0 [DEBUG] G55 on line 3 [DEBUG] G54 on line 5
As you can see, G54 appears at both the top and bottom.
This needs further filtering to ensure only the first actual WCS used in the program is considered.
1 year 5 months ago - 1 year 4 months ago #329166 by SanzuiWorks
I finally managed to implement this and it seems to work very well.
What it does:
- Detects the first G5x coordinate system (G54–G59.3) used in a G-code file
- Prints a debug log to the terminal: [DEBUG] G57 on line 4
- Sends the detected G5x via MDI so that the GUI updates to reflect the active work coordinate system
How I implemented it:
I added the following method to the StatCanon class in:
/usr/lib/python3/dist-packages/qt5_graphics.py
def set_g5x_offset(self, index, x, y, z, a, b, c, u=None, v=None, w=None):     print("[DEBUG-TRACE] >>> set_g5x_offset() is running <<<")     g5x = {         1: "G54", 2: "G55", 3: "G56", 4: "G57",         5: "G58", 6: "G59", 7: "G59.1", 8: "G59.2", 9: "G59.3"     }     print(f"[DEBUG] set_g5x_offset() called: {g5x.get(index)} on line {getattr(self, 'lineno', '?')}")     if not getattr(self, "g5x_mdi_sent", False):         if self.lineno > 0:             self.g5x_mdi_sent = True               print(f"[DEBUG] Sending initial MDI: {g5x.get(index)}")             try:                 import linuxcnc                 c = linuxcnc.command()                 c.mode(linuxcnc.MODE_MDI)                 c.wait_complete()                 c.mdi(g5x.get(index))                 print(f"[DEBUG] Sent MDI: {g5x.get(index)}")             except Exception as e:                 print(f"[ERROR] Failed to send MDI: {e}")     super().set_g5x_offset(index, x, y, z, a, b, c, u, v, w)
Notes:
- Make sure this method is placed inside the StatCanon class with consistent 4-space indentation.
- The initial G54 on line 0 and final G54 at the end (due to GUI reset) are ignored using: self.lineno > 0
- Only the first explicitly used G5x is applied via MDI.
- Verified to work reliably in QtDragon simulator config.
This improves usability by ensuring the GUI’s coordinate system matches what the G-code will actually use.
Tested with:
- LinuxCNC 2.9.4
- QtDragon (QtVCP)
- sim.qtdragon.qtdragon_tool_probe configuration
Let me know if this is helpful or if there’s a cleaner way to hook into the coordinate system logic.
Last edit: 1 year 4 months ago by SanzuiWorks.
Time to create page: 0.092 seconds
