Keyboard shortcut rempaping
- CallumRD1
- Thank you received: 3
24 May 2025 14:02 #329045
by CallumRD1
Keyboard shortcut rempaping was created by CallumRD1
I've been doing a bunch of machining on my freshly built mill running QTDragonHD and there's one thing that is absolutely throwing me off. I have a ton of experience running a Tormach on Path Pilot so I have established muscle memory for smacking the space bar to pause (feed hold) when proofing new code. QTDragonHD doesn't appear to have any shortcuts mapped to the space bar when a program is running.
Is it possible to remap the space bar to be pause (feed hold) when running programs?
Thanks!
Thanks!
- Thank you received: 2173
24 May 2025 16:00 #329054
Replied by cmorley on topic Keyboard shortcut rempaping
Which version of linuxcnc are you using?
- CallumRD1
24 May 2025 16:07 #329056
by CallumRD1
Replied by CallumRD1 on topic Keyboard shortcut rempaping
I'm running version 2.9.3
24 May 2025 16:49 #329061
Try this.
in your config folder add folders qtvcp/screens/qtdragon_hd
in the qtdragon_hd folder add this file, name it qtdragon_hd_handler.py
- CallumRD1
24 May 2025 23:12 #329082
by CallumRD1
It doesn't seem to be working. Do I need to call that python file somewhere?
25 May 2025 00:44 #329085
If you run linuxcnc from a terminal, do you see this text?
'Custom subclassed handler loaded for spacebar pause'
sometimes it's a focus problem, try pressing the 'G54' or 'ABS' button (after the program is started.). If that works I will look into why you need to do that.
- CallumRD1
25 May 2025 02:13 #329086
by CallumRD1
Thanks for the response. I am getting the line you asked about in the terminal. When I just tried using the space bar pause, it worked in all but one instance. I think you're right, it's a focus issue. In one instance, I had clicked the coolant button and then hit the space bar and the program failed to pause, but I was unable to replicate the behavior in the short session I had to test it this evening. I'll follow up if I'm able to reproduce the failure to pause.
But anyways, thanks for the help with this! I hadn't realized how much I use this feature until I didn't have it. When the tool is plunging rapidly, it's really nice being able to reflexively pause everything to check positions and the distance to go.
- CallumRD1
27 May 2025 21:25 #329276
by CallumRD1
I have confirmed, there is a focus issue. I need to click G54 or ABS or similar to move focus before the space bar works. That caused one slightly panicky moment when I hit it and nothing happened. (Fortunately, the code was right so it was fine, I just got scared for a moment.) Is there a way to set focus on cycle start or eliminate the need to move focus?
29 May 2025 01:25 #329334
Here is a slightly different file to try. replace the one I gave before.
I think there still will be a focus problem if you click the gcode display then spacebar.
But clicking the window or graphics display should refocus so space bar works again.
If you can confirm these things, I will look further into the gcode display problem.
Focus problems are always a pain!
29 May 2025 01:28 #329335
oops here is the new file.
Time to create page: 0.173 seconds
