Generating a own Popup
9 months 2 weeks ago #341339 by DemonClaW
Hey there,
im trying to get a popup done by myself, if i press a GUI Button i would like to get a Popup where i could have some checkboxes and monitoring some pressure inputs. I tryed to find something about the topic here but i didnt really found anything, is there a topic that already deals with this topic? Or is there someone who tryed something like that? Ive created my own .ui File, and tryed to implement it once by the main handler what just leaded a lot of crashes, then i tryed a own handler for the ui what in my opinion is the cleaner way, but sadly same result. i didnt touch any old code in the handler but it still crashes on a buttons i never touched or created myself.
Thx for any help
9 months 2 weeks ago #341343 by cmorley
Replied by cmorley on topic Generating a own Popup
can you post the ui file that defines your popup dialog?
9 months 2 weeks ago #341345 by DemonClaW
Replied by DemonClaW on topic Generating a own Popup
This would be the handler.py for the popup, the ui is currently a blank QDialog Window from QTDesigner nothing on it, i would add that after i got the window working like i want it to work. The problem is that it is something self created and nothing really proofed. I ocouldnt find a post here in the forum and the LinuxWiki side about Qtvcp and QtDragon isnt helping much ,too. Ive really no idea if im even on the right way.
9 months 2 weeks ago #341418 by cmorley
I'm sorry i will try to look at this on the weekend.
To be clear:
you want a customizable popup dialog/window that is show on HAL pin change.
You are otherwise using Qtdragon?
9 months 2 weeks ago #341420 by DemonClaW
I want to use a Button in the Main Ui to Open the Pop-up ui. The Pop-up ui will get some pressure Displays and checkboxes. But i dont See a Problem by implementing this. The Problem is that i didnt found anything about creating a Pop-up Like that. Im Sure If i Get that to Work, the Buttons etc. I can get it done by myself
9 months 2 weeks ago #341485 by cmorley
I forgot to ask if you are using 2.9 or master version? I have this working in principal in master branch.
Time to create page: 0.245 seconds
