QtFoam - 4-Axis Foam Cutter VCP - The Unicorn of LinuxCNC
- boozeman
- Topic Author
36 minutes ago #350667
by boozeman
QtFoam - 4-Axis Foam Cutter VCP - The Unicorn of LinuxCNC was created by boozeman
This tool was created with the help of Codex. If you have an AI allergy, stop reading and head for safer waters.
It was born purely out of my own selfish :UV Foam Cutter with proper and simplified Hotwire Toolpath Visualization. There's no "jogging" function, for instance, because it is practically useless when cutting wings for RC model aircraft. The MDI window contains a few definable macros as well as shortcuts for movement; for example, "400XU" converts to "G21 G90 G0 X400 U400". I have tested this for a couple of evenings on a machine equipped with proper capacitive endstops controlled by a Mesa 7196s, and nothing bad has happen.
Project is on Github, but I do not have time to handle pull requests. Clone and test the /media/kunena/emoticons/
As always "The Rear Lights Warranty" is ON!
[img][/img]
[img][/img]
- boozeman
- Topic Author
33 minutes ago - 32 minutes ago #350668
by boozeman
Replied by boozeman on topic QtFoam - 4-Axis Foam Cutter VCP - The Unicorn of LinuxCNC
Forum software do not like my links or pics and I can not anymore edit the post
github.com/boozeman/qtfoam
github/boozeman/qtfoam
Last edit: 32 minutes ago by boozeman.
Time to create page: 0.132 seconds
