My first effort
11 years 1 week ago #64069
by Micromet
Replied by Micromet on topic My first effort
While my first effort seemed to go OK - it was probably beginners luck - as I have had problems since in making multiple copies of the Harvest mouse keyring.
I'm not making it easy by trying to engrave stainless steel - which I now know is probably the hardest surface to engrave. And while production metal suppliers will tell you which type of Stainless Steel you are getting, many suppliers of these type of trinket items probably don't even know that there are different stainless steels. Anyway it seems I would be best if I used 416 stainless steel, then 430F, 303, 420F, 430, 304 and finally probably avoid 420.
On the tool front - I began using 30 deg x 0.1mm single flute carbide cutters that I sourced from ebay. Why? Because I knew no better and they were cheap. It seems I should be using 45deg x 0.1mm quarter-round micro-grain carbide cutters as these are less likely to fracture at the tip - which is something that was happening often as soon as the narrow angle cutter touched the stainless steel surface. I'm awaiting some of these micro-grain carbide cutters - but they are not cheap.
I was also running too fast a feed rate (400mm/min) and plunge rate (100mm/min). Again didn't know any better at the time - have now reduced that to 250 (feed) and 40mm/min (plunge) - seems to work better. And while I should be machining at something like 20-30,000 RPM or higher, my CNC machine has a maximum rpm of 15,000 (as shown by my excellent laser rpm meter - I recommend these to anyone who wants to calibrate their lathe, mill or cnc machine (less than £10 from Amazon - search digital laser photo tachometer)
I've also taken to covering the disc with a layer of 3-in-1 oil as a lubricant/coolant - I'm using Newplast modelling clay to act as a "bund" around the disc to keep the oil inside.
If any one has any comments to improve my current machining protocol - I'm as always - all ears
11 years 1 week ago #64072
by Micromet
My inkscape is not the latest - I'm using version 0.48. You need to install gcodetools as an extension - don't be put off by the Russian links -it's quite safe. Go to -
github.com/cnc-club/gcodetools
and download the ZIP file on the right-hand side, unpack that and follow the Install instructions at the bottom of the page. If you need any further help get back to me - but remember I'm no expert on INkscape either.
11 years 1 week ago #64087
by Sterling
I had .48 as well and saw on the 'Evil Mad Scientist' wiki that I should update to .91 Granted that was for the actual egg bot kit, but I figured I would be a good idea to update anyway, so I did. Check it out!! Under '[Extensions] there is a Gcode category already built in!!! (whoo-hoo!)
Next up; download the Hershey Text via Eggbot extension...
Replied by Sterling on topic My first effort
Micromet wrote: My inkscape is not the latest - I'm using version 0.48. You need to install gcodetools as an extension - don't be put off by the Russian links -it's quite safe. Go to - github.com/cnc-club/gcodetools and download the ZIP file on the right-hand side, unpack that and follow the Install instructions at the bottom of the page. If you need any further help get back to me - but remember I'm no expert on Inkscape either.
11 years 1 week ago #64131
by Micromet
My Mageia 4 Distro hasn't yet upgraded to the latest version of inkscape and trying it myself - I ran into a lot of dependency problems - which I didn't get with installing the Gcodetools extension. So I went down that latter path because I wanted the gcode function rahter than any new Inkscape options. But I have a warning - while the gcodetools extension worked perfectly, there were problems with how Inkscape appears to work that caused me some headaches. See
www.inkscapeforum.com/viewtopic.php?f=31&p=74792#p74728
where I recount the problem and various replies as to the cause. I'm not sure even now whether I have found the solution which does seem to be bound up in some way with the ability of Inkscape to preserve history for the "undo" function.
11 years 1 week ago #64136
by Sterling
I'll take a look, thanx.
So far the problem I've run into is that when I render the Gcode in Inkscape, I get a warning/error telling me I don't have anything in any layers, (I can't recall the exact image - I'll post a screen shot later) so every file comes up empty.
I did a [trace bitmap] then [object to path] then saved the file as an SVG. Next I opened it in QCAD, and rendered it out in Gcode through that.
Graphically, it looks good - but I haven't tested it yet.
Time to create page: 0.050 seconds
