Show your Machines
7 years 3 months ago - 7 years 3 months ago #140952 by ditechcnc
Replied by ditechcnc on topic Show your Machines
Linuxcnc with Mesa5i20 + 7i33
HURCO BMC40 with Fanuc servo and spindle
Youtube Link.
Last edit: 7 years 3 months ago by ditechcnc.
7 years 3 months ago #140954 by ditechcnc
HURCO BMC20 with Linuxcnc
open loop
sanmotion Q servo with Fanuc spindle
Youtube Link.
7 years 3 months ago - 7 years 3 months ago #140957 by ditechcnc
HURCO KM3P with Linuxcnc
close loop with Mesa5i20 + 7i33
CMC Dc servo motor
Youtube Link.
7 years 3 months ago #140958 by tommylight
7 years 3 months ago #140961 by ditechcnc
Bridgeport V2XT with Linuxcnc
open loop
Sanyo denki PY2 servo with delta VFD
Youtube Link.
6 years 3 months ago - 6 years 3 months ago #174132 by ississ
Replied by ississ on topic Show your Machines
1. A router of my own design, finished at summer 2010
Original configuration from 2010:
Spindle bearings needed a replacement (this was expected)
All steppers are changed to a bit more powerful (and the drivers) and the latest upgrade was the PC.
Controlled with parallel port and a self made opto-bob.
1200mm/min on all axes, spindle 20000rpm 100W.
Things made:
50 year birthday present for my brother in law, a wooden wrist watch: case (part 1)
Keyboard from pear wood: pcb (part 1)
2. Converted Optimum BF20L, finished at 2011
Just installed on the new table, almost ready:
Only the PC is upgraded last year (the old P4 thing stopped working correctly)
Cotrolled with parallel port and a self made opto-bob.
2100mm/min on all axes, original spindle 30-3000rpm
Things made: keyboard front plate
3. Restored CNC lathe17M00Bф30. Work is still in progress (casing etc) but fully functional.
About 10 years unused in a warehouse before I got this. Everything was disassembled (even the ball screws), cleaned, painted etc. Only some transformers, contactors, motors and encoders are left of the original electric parts. Everything else needed a replacement ;)
Controlled with a 5i25+7i76. Spindle motor is also changed from the original 1.1kW 170V DC to 1.5kW 380V 3-phase motor with a VFD.
8- position tool turret, driven by the original 50W 380V 3-phase motor with an AVR controller. The tool changer can be controlled with a serial port and I wrote a small python code (using manual tool change as an example) to use the changer easily from linuxcnc.
3000mm/min on both axes, spindle 50-6000rpm (with manua belt gear change)
Condition when received late 2013:
Work in progress 2014:
Lights 2016:
Things done: hose adapter thread
Last edit: 6 years 3 months ago by ississ. Reason: missing images
The following user(s) said Thank You: Mike_Eitel, tommylight
Time to create page: 0.133 seconds
