4x8 Plasma Table
6 years 3 months ago #173427 by CBEAR
4x8 Plasma Table was created by CBEAR
Well, I started the actual build in March, but I've been planning it for around 7 months. It's almost done, just have that last 1% to finish up and then it will be put to use to replace my 4x4 table. I'm coming from Mach 3, and I'm not very good with software, so the computer part has been the hardest thing for me to do so far!
The following user(s) said Thank You: tommylight, Clive S, johnmc1
6 years 3 months ago #173433 by tommylight
Replied by tommylight on topic 4x8 Plasma Table
Very nice, indeed ! :)
If that is a water table, please do not leave the Hypertherm under it.
6 years 3 months ago #173436 by CBEAR
Replied by CBEAR on topic 4x8 Plasma Table
Thank you! It will be moved before I ever fill it up with water. It's just under there as storage right now.
I have a question. The way that my scribe is set up, I've got it all on one solenoid and controlled by different regulators after that. So it should home in the z, offset in the x and y, and then fire the solenoid which will send it to the plate and turn the scribe on. My scribe is on a mini spring loaded slide so that it can "float" on top of the material. Is it possible to just use a single solenoid using plasmaC? Or do I have to use two?
6 years 3 months ago #173486 by phillc54
Replied by phillc54 on topic 4x8 Plasma Table
tommylight wrote: Very nice, indeed ! :)
Hmm, I guess I should move my little baby then. :)
Warning: Spoiler!
6 years 3 months ago #173487 by phillc54
CBEAR wrote: Thank you! It will be moved before I ever fill it up with water. It's just under there as storage right now.
If you wanted to. I think you could use just the scribe-arm output to both deploy the scribe an also turn it on. Just set the "arm-delay" to zero and the "on-delay" for enough time for the scribe to deploy and start.
6 years 3 months ago #173492 by rodw
Replied by rodw on topic 4x8 Plasma Table
Very nice. I like the rollers
Time to create page: 0.259 seconds
